????? ?? Again Kelly Need help.Again. Lost Picture & fax v..
Archived from groups: microsoft.public.windowsxp.customize (More info?)
I tried your below advice.
Click Start button
Click Run
Type: regsvr32 shimgvw.dll
Click the OK button
I get an error saying ... Loadlibary (shimgvw.dll) failed. System cannot find specified file.
I've checked. shimgvw.dll is located in the Windows\system32 dir ... and dllcache dir and
Lastgood dir. They are all the same in size, and version.
I copied the one from Dllcache into the system32 dir and ran the run command
regsvr32 shimgvw.dll again. Same thing. cannot find the file. But I know its there.
Even tried from run regsvr32 C:\windows\system32\shimgvw.dll ... Same thing
Anything else you can reccomend.
John
shimgvw.dll is the file and it should be in your \WINDOWS\SYSTEM32 folder. If that file
is in your \WINDOWS\SYSTEM32 folder:
Click Start button
Click Run
Click the OK button
Then open either Windows Explorer or My Computer, right click an image file, then left
click: Open With/Windows Picture and Fax viewer. Then you'll know that the viewer runs.
If you double click an image file, and it doesn't open in the viewer, then you will have
to associate the file extension for that image file type with the Windows Picture and Fax
Viewer.
T.C.
t__cruise@[NoSpam]hotmail.com
Remove [NoSpam] to reply
<Curly@me.com> wrote in message news:YmIKc.3560$Qv4.951@lakeread03...
> I've used your Picture & Fax restore and it doesn't help.
> I've tried to use it in the find program with no luck. Just a big clunk.
> Which means to me the file thats used is gone.. Can yiu or somebody
> tell me what file is run or used too open the MS Picture & Fax viewer.
> Appreciated the help. John
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.722 / Virus Database: 478 - Release Date: 7/18/2004
4 answers Last reply
More about kelly help again lost picture
  1. Archived from groups: microsoft.public.windowsxp.customize (More info?)
    Curly--
    What OS do you have? XP SP1?
    Three things:
    1) Do you have any system restore points you can try prior to when this
    happened? You can put "restore" in the run box and click on the rstrui
    folder and try SR.
    2) Run SFC (System File Checker) by putting "sfc /scannow" no quotes space
    after "c" in your run box and have your XP CD handy.
    The idea here is to check most of your files and replace damaged ones from
    the DLLCache folder. There should be no down side and this might help bring
    back files needed for it.
    3) Try restoring the file association with the download from Doug's site I
    linked you to.
    Chad Harris
    __________________________________________________
    <Curly@me.com> wrote in message news:tRUKc.3773$Qv4.962@lakeread03...
    > Click Start button
    > Click Run
    > Click the OK button
    > dllcache dir and
    > command
    > know its there.
    > thing
    > John
    > If that file
    > Click Start button
    > Click Run
    > Click the OK button
    > file, then left
    > the viewer runs.
    > you will have
    > Picture and Fax
    > Viewer.
    > T.C.
  2. Archived from groups: microsoft.public.windowsxp.customize (More info?)
    Check your settings here or download the restore from line 80:
    http://www.kellys-korner-xp.com/xp_tweaks.htm
    [HKEY_CLASSES_ROOT\SystemFileAssociations\image\OpenWithList\shimgvw.dll]
    [HKEY_CLASSES_ROOT\SystemFileAssociations\image\ShellEx\ContextMenuHandlers\ShellImagePreview]
    @="{e84fda7c-1d6a-45f6-b725-cb260c236066}"
    [HKEY_CLASSES_ROOT\SystemFileAssociations\image\ShellEx\PropertyHandler]
    @="{eb9b1153-3b57-4e68-959a-a3266bc3d7fe}"
    [HKEY_CLASSES_ROOT\SystemFileAssociations\image\ShellEx\{BB2E617C-0920-11d1-9A0B-00C04FC2D6C1}]
    @="{3F30C968-480A-4C6C-862D-EFC0897BB84B}"
    All the Best,
    Kelly
    Microsoft-MVP Windows® XP
    2004 Windows MVP "Winny" Award
    Troubleshooting Windows XP
    Taskbar Repair Tool Plus!
    http://www.kellys-korner-xp.com/taskbarplus!.htm
    > Click Start button
    > Click Run
    > Click the OK button
    > dllcache dir and
    > command
    > know its there.
    > thing
    > John
    > If that file
    > Click Start button
    > Click Run
    > Click the OK button
    > file, then left
    > the viewer runs.
    > you will have
    > Picture and Fax
    > Viewer.
    > T.C.
  3. Archived from groups: microsoft.public.windowsxp.customize (More info?)
    Kelly, I had exactly the same problem as yours and no one could help, then
    recently I loaded XP SP 2, and the P&FV returned. Good luck. I'm V Happy now.
    > All the Best,
    > Kelly
    > > Click Start button
    > > Click Run
    > > Click the OK button
    > > dllcache dir and
    > > command
    > > know its there.
    > > thing
    > > John
    > > If that file
    > > Click Start button
    > > Click Run
    > > Click the OK button
    > > file, then left
    > > the viewer runs.
    > > you will have
    > > Picture and Fax
    > > Viewer.
    > > T.C.
  4. Archived from groups: microsoft.public.windowsxp.customize (More info?)
    Glad to hear it, thanks for the update.
    All the Best,
    Kelly
    "ReterS" <phhsullivan@bigpond.com.hol> wrote in message
    news:9518A387-2477-4825-86C0-98AA6461C6AD@microsoft.com...
    > now.
    >> All the Best,
    >> Kelly
    >> > Click Start button
    >> > Click Run
    >> > Click the OK button
    >> > cannot
    >> > and
    >> > dllcache dir and
    >> > command
    >> > I
    >> > know its there.
    >> > Same
    >> > thing
    >> > John
    >> > folder.
    >> > If that file
    >> > Click Start button
    >> > Click Run
    >> > Click the OK button
    >> > file, then left
    >> > the viewer runs.
    >> > then
    >> > you will have
    >> > Windows
    >> > Picture and Fax
    >> > Viewer.
    >> > T.C.
    >> >> clunk.
Configuration System32 DLL Windows XP
