Hi, this is going to my first time building and I wanted to make sure that all the part will be compatible with one another. My goals with this cpu are mainly for gaming, some OC'ing down the line, and SLI in the future . I am hoping you guys can give me suggestion on a build that I put together.
My main concern is the heat sink and the memory. Will there be a problem with airflow or fitting both of these components into their respective areas? Is the memory compatible with the mother board?
Also, should I get the ASUS P8Z68-V-PRO or the ASUS P8P67 PRO (REV 3.1)? Kinda in a dilemma.........
Thanks in an advance for the help!
CPU: Intel Core i7-2600K Sandy Bridge 3.4GHz
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115070
Heatsink: COOLER MASTER Hyper 212 Plus RR-B10-212P-G1 "Heatpipe Direct Contact" Long Life Sleeve 120mm
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
Motherboard: ASUS P8Z68-V PRO LGA 1155 Intel Z68
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131730
Storage: Western Digital Caviar Black WD1002FAEX 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136533
Memory: CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 15000)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233170
PSU: OCZ ZX Series 1000W Fully-Modular 80PLUS Gold High Performance Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341045
CASE: Corsair Graphite Series 600T CC600TM Mid-Tower http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.723284
Optical drive: Sony Optiarc CD/DVD Burner http://www.newegg.com/Product/Product.aspx?Item=N82E16827118040
OS: Microsoft Windows 7 home
GPU: ASUS ENGTX560 TI DCII TOP/2DI/1GD5 GeForce GTX 560 Ti (Fermi) 1GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121425
