Hello!
i am starting to look into using nvidia "surround vision" with my system, and have a few questions I hoped you guys could answer.
My current system is:
P55 EVGA SLI mobo (P55)
i7 860 (OC to 3.66)
H50 cooler in push/pull
8GB DDR3 1600
850W corsiar PSU
Antec 900 modded case
7 fans total
2 12" cold cathodes
1 evga gtx 580
1 sata 6GB/s HD
2 sata 3GB/s HD
1 Sata 3GB/s SSD
TV tuner
I can post models if you guys think it matters.
I have 2 1920x1080 monitors, and am looking to get a 3rd, for the surround. I have an old GTX 275 I can use for graphics for the 3rd. I realize that this GPU will not help with SLI, but I am looking to get a 2nd 580 in the near future.
I also realize the limitations of P55 (8x8) when dealng with SLI, but from my understanding the performance loss is very small.
I currently game on 1 monitor, I use the 2nd one for work.
Questions:
Will my PSU power 2 580's?
Ive never had an SLI setup, I usually buy single high end single cards instead, the cards stack right up in the mobo, what kind of heat issues will I have?
I dont fully understand why you would need something like head2go, do the cards not have the capability to use 3 monitors (the 2 580's) in a surround vision setup?
I play a vast array of games, MMO's (wow and rift) FPS (BF and COD) and RTS. will a 3 monitor system work with most games? I remember when BF2142 came out, there was no widescreen support, because it was thought to give an advantage.
Are there any other factors I need to take into consideration before I purchase another monitor, and another 580.
Thanks as always
i7 860 (OC to 3.66)
8GB DDR3 1600
850W corsiar PSU
7 fans total
2 12" cold cathodes
1 evga gtx 580
1 sata 6GB/s HD
2 sata 3GB/s HD
1 Sata 3GB/s SSD
TV tuner
Questions:
Thanks as always
