Closed Solved
HEAR SOUND FROM MY SYSTEM ?
while playing games like saint row 3, metro 2033 i hear a sound from my cabinet am not sure whether it is from gpu cpu or the extra 120mm fan tat i installed, oly while playing the games at high resolution i hear sound... my config is
Intel i5 2500K...
Asus P8H61...
4gbX2 corsair vengeance
western digital caviar 1tb
Cooler Master 430 black elite Mid tower
Cooler Extreme Power Plus 600w
Asus GTX 560 Ti Direct Cu II
7 answers Last reply Best Answer
More about hear sound system
  1. is it a high pitched whining sound?
  2. not high pitched but sound of high speed rotating fan
  3. and is it usual tat when playing games with high resolution there will some sound ?
  4. Best answer
    if its fan noise then it could be from the gfx, the cpu or the psu. they all have fans. the hotter the system gets the harder the fans work.
    the base of the problem is likley to lie with the case. as you only have 1 front induction fan on the front and maybe 1 on the side but you have 5 potential exhaust fans. meaning your case will be starved of air so wont cool effectively.
    this then leads to higher internal fan speeds as everything fights for the limited air that is there... leaving the side panel off will help in 1 respect. your system wont have a negative preasure and the fans will be able to draw the air they need. but the rest of the components wont get cooled effectivley as there will be little overall movement of air around the case. closing the case will resolve this...
    in the short term you can turn of 1 or 2 of the extractor fans at the top of the case. and maybe move a fan from the top to the bottom next to the psu if you can, and set it to intake.
    leaving 1 at the top and 1 at the back to exhaust the whole system. over all this should ballance the air flow and help reduce noise.
  5. the noise is not dangerous if it is fan noise, whether it is too much for you is a different issue.
  6. I have that case which came with one 120mm front intake.
    I've added a 120mm rear exhaust and 2x120mm top exhaust.
  7. Best answer selected by ganpati.
CPUs
