Hello,
Im on the edge of insanity with these RAM, so i hope someone out there can help me with my problem. First, let me just quick describe my computer:
Motherboard: Gigabyte GA-Z68X-UD3H-B3
Ram : Corsair 2x4096 MB DDR3 1333 MHz XMS3
Power: 600 Watt Corsair Gaming Series GS600
CPU: Socket 1155 Core i7 I7-2700K 8 MB
HDD: Crusial m4 SSD
gfx: Sapphire Radeon HD 7850 2GB GDDR5
Warning - abit long description here:
So, i bought this PC in april and it has, until now, been working perfectly (been using it everyday more or less). However, aproxx. two weeks ago i got my first PC crash. I was playing a game and the picture and sound just froze (acutally the sound keep making the same noise like it was stuck). When i rebooted my PC i wouldnt boot. It would only startup for 1-2 seconds and then shut down itself again, and continue to do this until i shut down the power. I then started to unplug my HDD, gfx card and so on, until only the RAM was plugged into my machine, and it wasnt until I unplugged one of the RAM sticks (RAM stick A) that the computer would boot again (now only with RAM stick B inserted). I tried RAM stick A in all the memory slots with the same result: it wouldnt start. Then tried RAM stick B in all memory slots with no problem.
It seemed clear to me, that the problem was with the RAM stick(s) so i returned them to the place i bought them.
However, according to them, there was no problem with the RAM sticks. They had tested them using Memtest86+ and encountered no error, and so they returned my RAM.
I then inserted both sticks in my computer again and it seemed to work now, because I could boot and use my PC. However after 25-30 minutes i experienced the same problem again.
So then it seemed that maybe my motherboard had a problem so i tried another set of RAM-sticks (the same kind) that I borrowed from a friends computer in my computer.
I also tried my RAM sticks in his computer (he has the same motherboard but otherwise a slightly different computer).
The result was what i expected. Now my computer would work fine, however his PC would crash after 25-30 min. All i did was to boot into windows, start some music and movies and a few games to "stress" the computer.
I figured i should try Memtest86+ on both computers (although i never tried this program before). The same result was seen. My computer could complete a few tests, while his computer (with my RAM sticks) crashed before completing 1 test.
So i returned my RAM sticks once again to the place i bought them, with a description that they should test the RAM sticks for a longer time. This time the tested them for 72 hours in Memtest86+, but one again did NOT encounter any error.
So now i just receieved my RAM stick again from them, and this time i instantly tested them in Memtest86+ (before booting in windows and waiting 25-30 min to see if it would crash again).
and now, strangly enough, i have been running the memtest86 for 1½ hours with NO errors.
Im sorry for this very long story, but if any of you actually read all of it, do you have any idea WHY my RAM sticks CAN run endless in memtest86+ but seem to crash in windows and games, movies ect. after 25-30 minutes ?
Im starting to get really frustrated here. You could say that maybe i should just buy a couple of new RAM sticks and it probably will come to this, but im actually afraid that the same problem will happen again some time....
Many thanks in advance to any advice that you guys have....
HDD: Crusial m4 SSD
