Will this pc work im looking to build my first
  • Power Supplies
  • Components
  • Product
Last response: in Components
December 20, 2011 6:35:30 PM
i7 2600k quadcore sandybridge 3.4 ghz 319.99 95w
asus maximus iv extreme z lga-1155 329.99
coolermaster hafX 199.99
2 amd radeon 6970 hds 339.99 550w x2
2x4gb dimms corsair vengance 1600 mhz 77.99
250 gb hdd 129.99$
24x dl dvd rom 32.99
w7 home 64bit 99.99
nzxt sentry lx 49.99
SILVERSTONE ST1500 1500W ATX 12V 2.3 & EPS 12V SLI Ready 80 PLUS SILVER Certified Active PFC Power Supply 349.99
cooling 100$
like the psu says 4 8 pin but the gpus say 6 and stuff like that..
More about : work build
a b ) Power supply
December 20, 2011 7:02:08 PM
Hi and welcome to Tom's forum.
That can works without problems, but that PSU isn't modular, is expensive and isn't very good compared with other at same price.
This: http://www.newegg.com/Product/Product.aspx?Item=N82E168... is much better than that Silverston, modular and less price, can handle that rig without problems.
Another option is this. http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Any good PSU from 750W or above can handle that rig.
m
l
December 20, 2011 7:03:14 PM
If you change RAM then it should work. i7 2600k doesn't support 1600MHz memory only 1333 and 1066 DDR3.
If you are a gamer (probably you are) then choose more GB of HDD about 750...
m
l
December 20, 2011 7:16:32 PM
whats the best mem i can get for the same price then? and id like a bigger hdd but im kinda getting more exspensive then i had anticipated
m
l
December 20, 2011 7:21:24 PM
will this work for it ? gskill sniper 1333
m
l
December 20, 2011 7:22:31 PM
thank you :)  just curius where doi get notifications of replys on my posts? im just going back to the fourum page and finding my post
m
l
a b ) Power supply
December 20, 2011 7:22:40 PM
Don't change your RAM, that's the worst way that you can go...
m
l
a b ) Power supply
December 20, 2011 7:27:23 PM
soadnick i dunno where you got yer info but the 2600k can use any memory speed that the motherboard supports. yes the cpu officaly supports ddr3 1066/1333 but that doesnt limit the speed of the ram on the motherboard. if your gonna limit yourself to the slower speed ram then make sure it has similar latencies to the cpu's mmu to get the best from it...
you can bang in 2200 ram and it will work quite happily.... if his motherboard supports ddr3 1600 then he will have no issues. (you have to check this mind. some boards will support 1066/1333/1600+ oc/2100+oc
if you notice there is no support for 1800 on this imaginary board and if you tryed using it. its likley that you would have issues and be forced to run the ram at the slower 1600... which isnt entirely a bad thing as you can then drop the latency and make the ram more efficent. to the point that it will run slightly more efficiently than if you ran the ram at its original speed).
m
l
a b ) Power supply
December 20, 2011 7:36:38 PM
Check this picture:
1st tab > Profile tab: Your profile
2nd tab > Threads notifications > you must configure your profile for subscribe automatically to a thread after post an answer.
3rd tab > Private messages
If you can not see that square, check the option in the red square.
m
l
December 20, 2011 7:54:48 PM
thank you this is what i thaught, so im right in thinking corsair 1600 vengence is better than gskill sniper 1333 right?
m
l
a b ) Power supply
December 20, 2011 8:02:28 PM
Yes sir
m
l
December 20, 2011 9:46:15 PM
goodwill this setup run most games maxxed?
m
l
a b ) Power supply
December 20, 2011 11:03:17 PM
Sure will do, just make you sure of get a fan controller for that case since at full load is a little loud
m
l
December 21, 2011 5:24:33 PM
nzxt sentry already in the build parts :)  idk if youd know but on average how much would this weight? i dont wanna build it then pick up a 80 lb pc that i just put 2500 into
m
l
