Folks,
I installed a second 580gtx into my system. The MB is a evga x58 ftw3. The 3 available pci-e slots are two 16x and one 8x. The two 16x of course are the ones I used. They are close together. If I separated the cards to provide a slot in between them, then the lower card will run at 8x in slot 3. So with the cards hugging each in slot 1 and 2 the temperature is as follows....The upper card will get up to 80c and the lower card will stay around 48 to 50c. running a game. They drop in temp as soon as there is no loading.
Think the temps are too high? The case is a coolmaster..tall tower simular to the haf. Lots of fans. 1200watt power supply. Lots of air movement.
About the only solution I can think of is to get an asus mb where the pci-e slots are futher apart. Any thoughts?
Lazduc
Lazduc
