Tom's Hardware > Forum > Storage > Hard Disks > HDD and FDD problem
I recently installed a new IBM 30GB HDD (7200rpm) in my computer as a master drive and changed my existing 4.3GB HDD as slave drive. I was able to partition and format the new drive into 10GB each. When I loaded windows 98 to the new drive, my computer hung up. I tried loading 3 time with the same result. I then removed the new drive and put my old drive back in as master and reset the BIOS. My computer didn't work now. Every time I turned on my computer and after some normal bootup message, the last message on the screen that read "FLOPPY DISK FAILURE [E0]" and everything froze up. I exchanged a known good FD and cable with no success. Help! Thanks.
Sponsored Links
Double-check jumpers and check boot sequence in BIOS.
Rob
Please visit <b><A HREF="http://www.ncix.com/shop/index.cfm?affiliateid=319048" target="_new">http://www.ncix.com/shop/index.cfm?affiliateid=319048</A></b>
Reply to Arrow
There are 710 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 TH won the Freshman badge
  • 01:00 exploresalot won the Freshman badge
  • 01:00 mlg779 won the Freshman badge
  • 05:31 Mysteic won the Sophmore badge
  • 01:00 listerd won the Freshman badge
  • 01:00 stephen98146 won the Uniformed badge
  • 01:00 LANKO1982 won the Uniformed badge
  • 01:00 sitec won the Uniformed badge
  • 01:00 iiraymoii won the Freshman badge
  • 03:27 cjl won the CPUs badge
