Closed
Radeon HD 6950 help
July 21, 2011 8:48:29 AM
hi
I want to buy a 6950 1gb my budget is $250 and theres like 5 6950 from newegg for $240-$250..im buying one now and later geting othere for BF3,so i want to know whats the best 6950 1gb i can get for $250.
http://www.newegg.com/Product/Product.aspx?Item=N82E168... $240
http://www.newegg.com/Product/Product.aspx?Item=N82E168... $245
http://www.newegg.com/Product/Product.aspx?Item=N82E168... $248
http://www.newegg.com/Product/Product.aspx?Item=N82E168... $250
pc spec
AMD Phenom II X4 955 Black Edition
ASUS M5A97 AM3+ AMD 970
G.SKILL Ripjaws Series 4GB (2 x 2GB)
case RAIDMAX Tornado
LITE-ON DVD Burner
Seagate Barracuda 500GB 7200 RPM 16MB
More about : radeon 6950
Best solution
a c 129 U Graphics card
July 21, 2011 9:57:00 AM
Why not go with the Gigabyte with the factory OC to 870MHz core?:
You have a warranty on a decent OC with this thing. Seems like a great choice.
July 21, 2011 10:11:44 AM
cool.thx
Score
July 21, 2011 10:11:51 AM
Best answer selected by dx66.
Score
a b U Graphics card
July 21, 2011 2:19:02 PM
i would have to say go with the XFX. Lifetime Limited Warranty.
I have dual 6950's and they work great.
My 2 cents are to get 1 6950 now. register it. then latter on when you need more power get a 2nd 6950 xfx.
Score
a c 272 U Graphics card
July 21, 2011 5:12:02 PM
This topic has been closed by Mousemonkey
Score
