Firstly, thank you both for your replies! I will apologise now if I come across in a poor light with how I say this but:
mactronix said:
Your a little off the mark there friend. Its not a case of the card having 1GB of system memory dedicated to it its the operating system that is the issue.
Without going into all the technicality of it and to keep it simple, basically the operating system can address 4GB of Memory. 1GB of that is what is on the graphics card some is reserved for the OS itself and you get whats left for applications.
Going to a 64bit operating system is what you need to do to get all your memory available to use. This wont give you a huge boost in performance however so its worth bearing in mind when deciding if the upgrade is worth while.
I run all the peripherals i used to run back when using XP with my 64 bit W7 PC, i mention it because the lack of compatibility was used as a reason not to go 64 bit by some but there really is no reason not to these days, just about every thing i have installed or downloaded has worked fine or has had a 64 bit version.
Mactronix
I'm afraid you might be a little off the mark too but probably from my poor explanation. I understand 32bit and 64bit etc. and am quite comfortable to make the switch, graphics cards aren't my strong suit. However fslateef is definitely incorrect as the maximum my mobo will support is 4GB and I know that under 32bit it can only address roughly 3.25GB.
Back to my point, the graphics card has 1GB of GDDR5 memory on it (i.e. dedicated and TOTALLY separate from the system RAM). However the store that built the PC for me have set it up so that 1GB of my system RAM can also be addressed by the graphics card if needs be and all i want to do is remove this. I know that the RAM isn't used unless necessary but I'd rather if it wasn't available to my graphics card full stop!
I am attaching screen shots to prove my point about dedicated RAM (the GDDR5) and available RAM (the DDR2 attached to my mobo).
Here the catalyst control centre is showing the GDDR5 on the graphics card itself
Here dxdiag is showing the amount of RAM the graphics card can use if necessary which includes the 1GB GDDR5 on the graphics card.
So, can either of you two or anyone please assist me?
Thanks
Aventura54
P.S. I am going to run GPU-Z now
