This build is about a month old and was working fine, all components are new. Last week I turned it on and got sparks and smoke from the power supply. After that it wouldn't start so I got out my multimeter and began checking voltages on the board. The s bridge led will light when power supply is turned on. When I checked the power switch terminals the board started and the fans started working. I had made the connection, but the power switch would not start the board. However, I got no video. I did not have a speaker plugged in.
A few days later I was going to wire up a speaker and count the beeps but now the board won't start under any conditions.
Here are the details:
1. Power supply fried, board wouldn't start.
2. S Bridge led will light.
3. Board did start once when power switch terminals were connected but no VGA. Will not start now.
4. I reset the CMOS during diagnostics. No help.
5. I replaced the RAM stick.
MB=ASUS M4A88T
RAM=GSkill DDR-3 1600
PS=Zumax 550 watt.
Case=1 unit rack mount server
CPU=AM3+ 3 core 2.8 mhz
How can I test the MB to see if it is fried? Any other suggestions are appreciated.
Thanks!
MB=ASUS M4A88T
PS=Zumax 550 watt.
Thanks!
