Been a long long time, since Ive bought a sound card.
Had a audigy2 since 2002 roughly. Never seen a point to upgrade it. I only use stereo headphones.
Since the card broke, doesnt work anymore.
Im looking to replace it.
Im a vocal artist. I used my audigy2 to record vocal.
So any recommendations would be great.
24bit+ recording is preferred.
Then any sound card. That would maybe gain some performance from, would be nice. Like less taxing on my CPU for instance.
With my current on-board audio. I get slight whitenoise, when i record.
anything under 150. Cheaper being better. Or should I say best bang for buck.
Thanks.
Thanks.
