Yes No
Ads
Tom's Hardware > Forum > Systems > Homebuilt > What parts do i need to build a 1 terabyte pc
Forum Systems : Homebuilt What parts do i need to build a 1 terabyte pc
I am going to build my first pc and need info on the best hardware and best supplier. I live in South Africa and will not pay the 1000% markup to these daylight robbers (suppliers). Please give me advise,suppliers etc. Kind regards, Cobie.
Reply to Cobie
In answer to the question in your title, you need a 1TB Hard Disk Drive.
3 recommended are:
WD Caviar Black 7200rpm
SeaGate Barracuda 7200rpm
Samsung SpinPoint F3 7200rpm
------------------------------ ~i5-2500k @ 4.0GHz w/ Freezer 13
~8GB 1600MHz Vengeance RAM
~ASUS P8Z68-v PRO
~Gigabyte GTX 560Ti @ 900MHz
Reply to AdrianPerry
Do you need advise on other parts than a 1TB drive?
------------------------------ Intel Core i3 2100, Intel DH61WW MoBo, Corsair Value 4GB DDR3, EVM (Dynet) 2GB DDR3 1333Mhz, 500GB SeaGate Barracuda, Frontech Imagine Case, Corsair CX430
Reply to 008Rohit
3 recommended are:
Hi Adriaan,
Thanks for the info so far. I kindly ask that you give me a list of all of the hardware that i need. If you have suppliers in mind, that will be grearly appreciated.
Reply to Cobie
If you could fill out as much as this build template as possible: http://www.tomshardware.co.uk/foru [...] ild-advice It will enable myself and others to give you more accurate build advice :)
As for suppliers, I'm UK-based so I really have no idea there sorry.
Message edited by AdrianPerry on 09-22-2011 at 12:28:54 PM
~ASUS P8Z68-v PRO
Thank you for the message. Yes please i neea all of the hardware that is needed to build a mega beast of a machine. The suppliers too ifg poss.
Reply to Cobie
I think he thinks that the more HDD space you have the more BEASTIER the rig becomes. Someone should help him. Also, If you are not going to pay a cent to suppliers, how are you supposed to buy your parts?
Message quoted 1 times
Message edited by ervinelim on 09-22-2011 at 12:47:27 PM
------------------------------ CPU: AMD Phenom II x4 955 BE Mobo: Gigabyte GA-M68MT-S2 GPU: PowerColor HD 6770 RAM: G.Skill 8GB DDR3 @1333 PSU: HEC 500watts Rapter II Case: Cooler Master USP 100 Red
My future build when Bulldozer and HD 7000 come out.
Reply to ervinelim
Thank you for the comment but i was born with a brain and understand economics rather well, you have to pay for the parts. You do not need to respond as i need help and not useless statements like yours. Good bye.
Reply to Cobie
I find that going to the 'Where to buy' page of major manufacturers like Antec can give a good list of places where you can buy parts:
http://www.antec.com/Believe_it/in [...] pe=%25E%25
I don't know if that will help to solve your problem of finding a supplier without a 1000% markup.
Message edited by Silvune on 09-22-2011 at 04:52:42 PM
Reply to Silvune
Hi, Thanks friend, i will research thoroughly, many thanks. Cheers
Reply to Cobie
If you wish to assemble a computer yourself, you should probably start reading a bit around, getting an idea about what components are needed and how do they fit together. Which are most important to what you want to do with your computer. Once you have done that, look at the graphs and reviews here at toms to get a good idea how best to spend your budget.
Then you can post your ideas on this forum and people can give you feedback on it.
That is what I did when I was new to this.
If you do not wish to spend time doing so, i suggest looking at the a prebuilt computer instead (there is a forum for that too)
Reply to koogco
Hi, thanks for the message. Point taken and i've started today to work through a number of sites regarding the building of a Pc and the hardware that they out line as to be considered for the various levels of requirement. Thanks again.
Reply to Cobie
First, there is no such thing as a 1 TB PC.
There is a 1TB hard disk drive, that you can put in your pc.
I suggest you learn what a "PC" is before going any further.
------------------------------ Core i3-2100/Asrock H61/8GB1333/XFX HD5850oc/WD Black 500/Antec 300/Antec EA380w bronze
Currently playing Deus Ex:HR a second time on Hardcore
Reply to geekapproved
I want to build an 1000 watt beastly pc.
how can I do this guise?
Reply to internetlad
your post was silly and pathetic get a life.
------------------------------ http://i46.tinypic.com/2l963uq.png
2500k|480 2-way SLi|EVGA Z68 FTW. AMD rig in user system configuration.
Notebook: Acer Aspire 5935G|Intel C2D T6600|3GB DDR3|Radeon 4570M
Reply to recon-uk
384, I'm pretty sure he's just mocking the poster. I found it kind of humorous.
WELL.....WELL, Another super dumb dip stick. I do not wish to waste my time, keep your crap for yourself and go and play somewhere else.
Reply to Cobie
No reason to lash out at someone who's trying to help. With over 4000 posts, he's probably one of the most knowledgeable people looking over your thread.
He's right though, building a computer is no walk in the park if you have no idea of what components are needed, let alone which do and don't work together.
Message edited by AdrianPerry on 09-23-2011 at 09:26:56 AM
~ASUS P8Z68-v PRO
Speaking of dumb stick......Like I said, there is no such thing as a 1tb pc. So your post doesn't even make sense, that is why I told you that you should learn what a PC is and the parts that make up a PC and go from there.
+1
Reply to recon-uk
What is a PC.....?
Reply to Cobie
this thread is now pathetic.
a mod will be here soon.
Reply to recon-uk
not sure if trolling or genuine.
Message edited by internetlad on 09-23-2011 at 11:37:35 PM
This topic has been closed by Area51reopened
------------------------------ http://i1123.photobucket.com/albums/l546/area51reopened/Moderator1-1.jpg
http://valid.canardpc.com/cache/banner/2383852.png
Reply to Area51reopened
There are 1500 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Gigabyte z77x not working with corsair tx750?
By smorizio, 4 hours ago:
[quotemsg=2611689,1,1216211]hi guys i need some help, im not getting any power to the...
Best offers
Top experts
