Ok, so I'm having some SLIGHT issues, nothing that I picture too major, or its not anything that's really major atm. I recently built a new computer, everything went together real well (as well as I had planned for the first built) and everything is running great once the computer is going.
The problem: during post (on boot) my computer shuts off and retarts the booting process, it only does this once and after that it continues to work fine and boots into the OS. BIOS shows no errors, and I'm completely stumped.
Specs:
CPU cooler:
-Noctua NH-C14 140mm x 2 SSO CPU Cooler-link:http://www.newegg.com/Product/Product.aspx?Item=N82E16835608020
HDD:
-750gb Western Digital Black HDD-link:http://www.newegg.com/Product/Product.aspx?Item=N82E16822136283
Memory:
-Patriot Viper Xtreme Series RAM 1600mhz (2x4 GB-8total)-link: http://www.newegg.com/Product/Product.aspx?Item=N82E16820220561
Processor:
-Intel Core i5 2500k CPU-link: http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
Power Supply
-Cooler Master GX 750W PSU-link: http://www.newegg.com/Product/Product.aspx?Item=N82E16817171053
Motherboard:
-Asus Sabertooth P67-link:http://www.newegg.com/Product/Product.aspx?Item=N82E16813131702
Case:
-HAF 932 Advanced Edition-link:http://www.newegg.com/Product/Product.aspx?Item=N82E16811119160
Graphics Card:
-EVGA Nvidia 560ti Crysis 2 special edition card-link:http://www.newegg.com/Product/Product.aspx?Item=N82E16814130628
How can I keep it from restarting during boot/what do you think is causing it, below will be some things I have tried to eliminate the problem.
Things I've tried to eliminate the problem: (things that I did that didn't help or change anything)
-Made sure that the motherboard had all brass standoffs for it so that it wasn't shorting out or anything
-Put another, lower end graphics card in to see if maybe it was drawing too much power
-Plugged computer into the wall instead of the surge protector
-I did a MemTest on the board to make sure it was compatible (it says that it is even tho its not on the list that the Motherboard came with)
-I reset the CMOS
-BIOS is up to date
Thanks in advance to any of you tech savvy folk that can help me, I will really appreciate it.
Specs:
CPU cooler:
HDD:
Memory:
Processor:
Power Supply
Motherboard:
Case:
Graphics Card:
-I reset the CMOS
-BIOS is up to date
