Hi,
I would greatly appreciate answers for the following questions.
- Will the case have enough room for the CPU cooler I've picked ?
- Is the Power Supply adequate ? It'll never be used for gaming. Might have one or two hard drives added in the future, and may be another 4GB RAM
Thank you for your time and input.
SM
Approximate Purchase Date: Sep 22 or 23, 2011
Budget Range: Around $600
System Usage from Most to Least Important: Running a database, and ETL software like Informatica. No gaming or movies or CAD or image processing.
Reliability, and stability are important
Parts Not Required: keyboard, mouse, monitor, speakers, OS
Preferred Website(s) for Parts: newegg.com
Country of Origin: NJ, USA
Parts Preferences: Intel i5 CPU. Ease of install, and maintenance is a must.
Overclocking: Most probably no.
SLI or Crossfire: Absolutely not
Monitor Resolution: 1024x768 or 1280x1024
Additional Comments: I'm building the system for my employer, and wish to stick with newegg.com due to fast delivery.
Parts:
1) Case: Antec Three Hundred Black Steel ATX Mid Tower
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129042
2) Motherboard : ASRock H61M-VS LGA 1155 Intel H61 Micro ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157241
3) PSU: Antec BP550 Plus 550W Continuous Power ATX12V V2.2 80 PLUS Certified Modular Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371016
4) CPU: Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor BX80623I52500K
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
5) CPU Cooler: COOLER MASTER Hyper 212 Plus RR-B10-212P-G1 "Heatpipe Direct Contact" Long Life Sleeve 120mm CPU Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
6) RAM : G.SKILL Ripjaws Series 4GB 240-Pin DDR3 SDRAM DDR3 1333
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231310
7) HD Disk : Western Digital RE4 WD5003ABYX 500GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136697
8) DVD Burner: ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
Total Price ~ $590
SM
Parts:
Total Price ~ $590
