Hi, so here's part 2 about my bios update problem.
Below you can find my initial post, detailing the problem. It's under . Read that first!
Additional steps I took since then: sent the laptop to a repair shop which came recommended by a well-respected bios site. They tried everything, and the laptop's fans do spin (meaning also the cpu fans), and the led does go on.. so that's an improvement, i guess. but since he doesn't have the original bios image for the laptop that's it.. I did send him the N61Ja.BIN located in C:\ which should be the original bios backup, but that didn't work.. none of the bios files from the asus website worked either..
Anyone have any suggestions? Or can provide me with the original bios image (207) for the Asus N61Ja-JX046X?
Hello,I wanted to update the bios, with an official bios update, from version 207 to 211. I didn't use winflash, I used easyflash in the bios. Everything seemed to be going okay; it deleted the old files, wrote the new ones, verified the new ones. Then it said: shutdown in/after 2 seconds and it shut down. Then nothing happened anymore. Power button completely unresponsive. The battery light was still on, and I'm not sure if I should've just waited... I didn't though, I thought I had to remove the battery, take the power off completely to be able to start it up again.
So I'm wondering: what are my options here? My warranty expired and I don't really have the money to send it in and pay hundreds of bucks on repairs.
Is there anything I can try? CMOS battery reset? Anything???
Please help me out! I would be very grateful
ps. What was sort of odd btw, was that easyflash said something like that it was an unsigned bios and if I wanted to flash it anymore, if i wanted to 'force' it or something. It was with 100% certainty the correct update from the Asus.com support site, so I didn't take that 'warning' seriously.
