hi everyone.
I've bought Asus P7P55D working fine for me untill today I'm having a strange issue regarding booting up my system. When I power on the MB. CPU_LED light blinks for less than a second and goes off , the whole system goes off and on again and again.
What I've done , removed everything on MB except power connectors 24pin and 8Pin.
tried clearing BIOS. but no result , also try to bootup with MemOk but still same issue.
Also checked whether I seated the CPU in place. No bent pins, socket also not damaged.
But when I remove the 8pin on top of MB the system gets on with steady red light of CPU.
I then tried to remove the CPU and power on the MB.. Still the same !!! .
Seems to me like MB doesn't even detecting the CPU at first place. Or maybe some other problem.
I thought for a sec it might be a PSU probelm so I've changed my PSU from Cooler Master GX-650W to brand new Corsair TX950 950W .. still the same.
Is it the faulty Motherboard ? or something else would work ?
Help needed !!
Help needed !!
