MOBO for xfiring HD 7950 directCUii
hey, i wanna xfire 2 Asus HD 7950 directCUii and im wondering what kind of high-mid MOBO i would need. Also i would like to get a new CPU that would accomedate the 3 of them.
8 answers Last reply
More about mobo xfiring 7950 directcuii
  1. Well, I could pick out some real expensive merchandise that I'm sure will work but I don't know if that would be what you want. You should give the budget amount that you want to have and whether you want AMD or Intel.
    Since your setting up Crossfire you will most likely be gaming and want an Intel cpu.
    ASUS Maximus V FORMULA LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 Extended ATX Intel Motherboard
    $279.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813131854
    Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000 BX80637I53570K
    $229.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
    I don't know if this is high end enough for you and I can go higher if you want.
  2. since you are only going 2 way xfire this may be more appropriate and will be fine for overclocking:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813131853
    Also, keep in mind the the Maximus is E-ATX and will only fit in a few cases.
    The i5-3570k (and the older 2500k) are the gold standard in gaming cpus.
  3. It wasn't an actual recomendation since the op didn't give a budget and I was more showing what can get suggested when you don't give a budget.
    Very true. Thanks for the clarification,
  5. thanks for the info guys! i was wondering if Corsair 9-9-9-24 1333 ddr3 ram will work in that MOBO Inzone listed. whats the deal with the #-#-#-# and the 1333? higher means better?
    also, ive got a 950 watt power supply. is that enough for 2 HD7950s?
    i have another question about over clocking, there is a catalyst progam that came with my video card that gives the option to overclock and boost fan speeds.. any suggestions? i remember years ago hearing stories of people melting there CPUs
    im also planning on purchasing that mobo and cpu that you listed Inzone, any other suggestions?? im going to need a new tower to fit all of these new toys
    is it easy to install a CPU to the board? i know how to apply thermal paste but thats about it when it comes to that. is there a youtube video you would recommend?
  6. The MB lists the ram that will work with the board and certianly 1333mhz will work and so will 1600mhz which is what would be a good choice. The 9-9-9-24 numbers are the timmings of the ram and higher is not better , lower is. So if you got 8-8-8-24 would be better.
    The 950w psu would be enough to run what you want.
    The overclocking of a gpu would not be very necessary in your case with two 7950's you will get plenty of performance. If you wanted to boost the clocks some you could but you wouldn't need to go crazy. Melting the gpu would be if you added too much voltage to it when overclocking.
    It is relitively easy to install a cpu into the MB socket , you just have to be extremely carefull not to bend any of the pins in the socket. You will never get them straight again and the board will be useless. Follow the instructions in the MB ownersd manual and you should be fine. You can also Google a youtube video on installing one.
    CORSAIR Dominator Platinum 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMD8GX3M2A1600C9
    $77.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820233283
    CORSAIR Dominator Platinum 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866 Desktop Memory Model CMD8GX3M2A1866C9
    $89.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820233284
    These are some of the new models that Corsair just released. If you would prefer less expensive models you cam look at these.
    CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ8GX3M2A1600C8
    $51.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820233147
    CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 15000) Desktop Memory Model CMZ8GX3M2A1866C9R
    $48.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820233184
    A case is more of a personal choice and as long as it has good air flow if you come across one that catche your eye then you should get it. You also have to decide if you want full tower or mid tower and how much you want to spend on it.
  7. So I bought that mobo posted, mounted in my tower and now putting everything together... It seems like there are alot of pins still sticking out that should have power. How come there is a 4 pin at the top and another 24 pin by the ram? What else should be getting power beside the easy ones like the rest of the hardware.
    This is my first install by myself and I don't wanna start anything on fire lol
  8. For LEDs on my tower, I got a phantom eATX edition for the Asus Maximus
Motherboards Asus CPUs HD Product
