Closed Solved
OCZ ModXStream 600W Power Supply Cable Length Problem
I am looking to upgrade my current build:
Intel Core i5 650
1TB HDD
OCZ ModXStream 600W
Crap Acer Motherboard
Crap Acer Case
Gigabyte GTX 560
8GB RAM
I would like to replace the case with the NZXT Phantom BLACK Enthusiast Full Tower Case however I do not want to replace my power supply. I have read that the cables of my PSU are too short. Can anyone recommend cable extensions that I can purchase to fix this issue? I am Canadian so I can only purchase from websites such as NCIX and CanadaComputers.
In addition, I want to replace my motherboard with the Gigabyte GA-Z68X-UD3H-B3 OR the Gigabyte GA-990FXA-UD3 motherboard. This depends on the CPU I will get. I am waiting waiting for NCIX to launch their boxing week sales so that I can see if they have a good deal on the i5-2500(k) or the FX-8150 or FX-8120. Also, with any of these motherboards, I will get 8GB of Kingston HyperX RAM for free. How does this sound? Thanks in advanced for any help.
6 answers Last reply Best Answer
More about modxstream 600w power supply cable length problem
  1. Best answer
    NZXT Premium Individually Sleeved Computer Cables 8PIN EPS/P4 Power Extension Cable
    http://ncix.com/products/?sku=52316&vpn=CB%2D8P&manufacture=NZXT
    http://ncix.com/products/?sku=62209&vpn=BFA%2DMSC%2D8EPS45KK%2DRP&manufacture=BitFenix
    http://www.bestdirect.ca/products/181108/CB-8M-8F/Works/
    You might need the 24pin ATX i'm not 100% sure.
    Here's a cheap one.
    http://www.bestdirect.ca/products/181122/CB-24F-24M/Works/
    btw i have two of those psu's = you'll need the 8pin for sure!
    Personally i'd go with the Intel platform = also i use Gigabyte mobo's exclusively
    Bestdirect and NCIX are owned by the same parent company.
    I usually just pricematch the items at NCIX.
    Ncix has nice cheap fast shipping as you probably know.
    Thanks for the recommendation. I will look into them more. And yeah, the Gigabyte motherboards are priced extremely well and CanadComputers is giving 8GB RAM for free with some of them on Boxing Week (26-31). I think I will go with Intel, however if there's a better AMD deal, I will go towards that... just waiting for 8PM EST for NCIX to launch their Boxing Week sales.
  3. Best answer selected by fuddy12345.
  4. On second thought, I might upgrade my power supply to SLI my GTX 560 in the future. Any recommendations?
    I am thinking of this one: http://ncix.com/products/?sku=63239&vpn=P1850SNLB9&manufacture=XFX
  5. i got nzxt red phantom and ocz gold 850watt psu plenty cable length on the cable.
    They are different series so length is not the same.
Power Supplies Cable Components
