Solved
High pitched noise, help please
New build, hearing a loud, high pitched, variable sound at the top of the MOBO near the CPU and the top MOBO heat sink. The 4 blue MOBO led's are also blinking and dimming/brightening in sync with change in the sound's volume.
The sound doesn't emmit until the windows loading screen appears. I've turned the computer on without the HDMI cable or USB mouse/keyboard and I don't hear the sound, though I confirm windows loaded successfully. When I plug the mouse/keyboard in the sound starts but is very quiet. When I plug the HDMI into the video card without the tv turned on the sound and light flashing increase in intensity. When I then turn the tv on the sound is loudest. The sound is far from the MOBO speaker. I think the CPU temps and voltage are ok, they are around 55 degrees celcius and 1.00 volt.
All parts are purchased from newegg.
Intel Core i5-2500 Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core
XIGMATEK LOKI SD963 92mm HYPRO Bearing CPU Cooler bracket included I7 i5 775 1155 AMD and dual fan push pull compatible
Rosewill BLACKHAWK Gaming ATX Mid Tower Computer Case
MSI P67A-G43 (B3) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
MSI R6950 Twin Frozr III PE/OC Radeon HD 6950 2GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card x2
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL7D-8GBXH
Western Digital Caviar Black WD7501AALS 750GB 7200 RPM SATA 3.0Gb/s 3.5" Hard Drive -Bare Drive
Seasonic SS-850HT 850W ATX12V v2.31,EPS12V v2.92 80Plus Silver Certified, Active PFC Power Supply - OEM
LG CD/DVD Burner Black SATA Model GH22NS70 OEM - OEM
Microsoft Windows 7 Home Premium SP1 64-bit - OEM
5 answers Last reply Best Answer
More about high pitched noise please
  1. Best answer
    I think your are not giving enough power to your CPU, stock voltage should be around 1,12V~1,22V (not sure, I'll have to check). However, your mobo manual should tell you the kind of error you're getting (it is coded with those LED's blinking)
  2. Nope, CPU voltage seems to be normal. 0.95V when idle, 1.27 when loaded. So I'm guessing it's a mouse/keyboard drivers problem. Try connecting both devices on different usb ports, and reinstall the latest drivers.
    I increased the CPU voltage from auto to 1,22V and the sound is gone! Thank you very much.
  4. Best answer selected by toskaboska.
  5. **UPDATE**
    After flashing my MOBO BIOS the "auto" voltage setting for the CPU Vcore now sets an adequate voltage which doesn't produce a high pitched sound.
New Build Systems
