Sign-in / Sign-up
Solved
System build of 2011
  • Build
  • Systems
  • Product
Last response: in Systems
September 24, 2011 4:32:07 PM
Hello,
How can I improve this system build to perform better?
GIGABYTE GA-Z68X-UD7
Intel Sandybridge i7-2600k
2x geforce gtx 580 Sparkle
2x G.Skill Ripjaws X 12800 C7 4G
Cooler master silent pro gold 1000
OCZ Vertex 3 120 GB
Noctua NH-C14
2x Thermalright Shaman
Nzxt Crafted series Phantom white
Seagate Barracuda XT 2TB
More about : system build 2011
September 25, 2011 12:31:55 AM
You would actually do just fine with 2x4GB 1.5V CAS9 1600Mhz kit instead of a CAS7.
The difference is really small in performance.
Noctua NH-D14 works a bit better than the C14.
That Vertex 3 has nice performance so, I think you are good with that.
Personally I would get Corsair HX1050 or Corsair AX1200 instead of that Cooler Master PSU.
But they do cost a bit more.
m
l
Best solution
September 25, 2011 8:19:58 PM
tantann said:
Hello,
OCZ Vertex 3 120 GB
Noctua NH-C14
Instead of those 580s and the Shaman coolers, get these. Best 580s ever: quiet, cool, fast. Plus double the framebuffer of your current selection.
As rvilkman said, the NH-D14 is better than the C14. You could also consider the Silver Arrow, whose fans have PWM.
The Corsair AX1200 is great.
I vote for the Crucial M4. With the new firmware, they're really fast. Get the 128GB version; if you want more, RAID will get you better performance than the 256GB version.
As for RAM, choose between this 1600MHz C8 kit or this 1866MHz C9 kit.
October 6, 2011 12:06:58 AM
tantann said:
Hi
insted of aircooling i was thinking about liquidcooling when i was reading the articale Getting More Performance From A Smaller PC. Any suggestions on what kind of system i should consider?
That was an interesting article. My suggestion would be to keep the motherboard they used but get the i5-2500K and the Corsair HX850. You probably only need 1 HDD, and I would stand by my 128GB M4 suggestion for your SSD. The RAM they chose is a little silly, so I would go with this kit or this kit.
m
l
October 6, 2011 4:34:07 PM
i'm sorry you must have misunderstood me because i still want everything as they were. The only thing that have changed is my choice of cooling system. Now i'm considering water cooling for my cpu and gpus.
m
l
October 6, 2011 7:12:38 PM
If you want a custom water cooling setup, I won't be able to help you much because I have no experience with that. You could use the Tom's build, or you could even stick with air cooling because it's effective, quiet, simple, and less risky.
m
l
October 6, 2011 8:24:13 PM
Best answer selected by tantann.
m
l
October 6, 2011 8:25:15 PM
thanks anyway nim Chimpsky
m
l
October 6, 2011 9:54:48 PM
You're welcome. Good luck with your build.
m
l
