Solved
Need RAM speed suggestion for 1333Mhz FSB
I will be using an asus G41 chipset motherboard with E8400 processor, probably at stock speed or a bit overlocked @ <=3.4 GHz (cpu clock between 333 to 400).
But I want to run 2x 4GB RAMs as tight as possible, 7-7-7-24 or better. So, will a pair of 1600MHz RAM be ok ? RAM clock speed will be 800MHz, right ? while cpu clock will be 333MHz. Will there be any synchronization issues or the system will run fine ?
Here are lists of RAMs I get to choose from :
http://www.flipkart.com/browse/computers/components/ram-20214?sort=price_asc&layout=grid&filter=data_rate_fa%3ADDR3%3E%3Edevice_fa%3APC%3E%3Ecapacity_fa%3A4.0&ref=57348bd3-898e-4669-9924-b323cceb1ec5
http://www.flipkart.com/browse/computers/components/ram-20214?sort=price_asc&layout=grid&filter=data_rate_fa%3ADDR3%3E%3Edevice_fa%3APC%3E%3Ecapacity_fa%3A8.0&ref=bdcca98b-c243-47e8-acea-e8
8 answers Last reply Best Answer
More about need speed suggestion 1333mhz
  1. Your links don't show what ram sets your going with, they just show a page with all ram choices.
    You may want to go with the 1333mhz ram so that the buss will be in sync and your overclock will go smoothly.
  2. Hmmm I had 2x 4gb 1600MHz GSKILL ripjawsX modules in mind. Heard higher clock rated rams can run tighter with low clocked FSB.
  3. any more opinions on what might happen if gone for 1600s instead of sticking to 1333s ?
  4. Best answer
    When talking about ram performance and useing one speed over another ther is no real performance difference that will be noticeable between 1333mhz and 1600mhz except that you think there is because 1600mhz sounds faster than 1333mhz. It is but the difference is not noticeable and the more important thing is having the system stable so that you dan do what really makes a difference and that is overclock. People can sometimes get stuck on thinking that ram makes a big difference in performance and it doesn't, your computers performance will be nearly the same with 1333mhz or 1600mhz.
    So if your computer will run fine and stable with what you end up doing to the 1600mhz (timmings) then go for it, but it seems to me that the overclock will be more important.
  5. ok, thanks. i will go for 1333s then.
    what i am basically doing is upgrading my c2d with more RAM, but will probably get a new system after 1.5-2 years, if i think more power is needed. and its too uncertain whether these RAMs will be of any good then even with oc. so, wont spend extra amount if unnecessary.
    among gskill and corsair, which is better in this category ? is there any difference between the ripjawsX/vengeance and the basic RAM from gskill/corsair, other than the heatsink (there will be slight oc, as much as this asus g41 permits probably ~3.4ghz for E8400)?
  6. The G.Skill and Corsair ram are pretty much equal in performance and quality. Corsair did just release a premium set that I have been looking at and trying to figure out if it's much better then the Vengence.
    By the time your ready or the new system your talking about DDR4 will be out.
    CORSAIR Dominator Platinum 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866 Desktop Memory Model CMD8GX3M2A1866C9
    $89.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820233284
    They don't have a 1333mhz set and the 1600mhz is the lowest for this new set.
  7. Best answer selected by Gamer100.
  8. thanks for everything. But I wonder why there are no other people around. :o
Overclocking RAM CPUs Motherboards Memory Product
