Solved
Cant create bootable usb drive POWER ISO
I just bought an SSD for my desktop, and have to wipe my current drive so that i can put a fresh install of windows on my SSD. I downloaded dban on my laptop (do all of my downloading etc on my laptop) and tried to use power iso to created a bootable drive for dban instead of wasting my money on dvds.
1) i tried to format the usb to fat32. Then ran power iso in admin mode. Then used the create bootable usb tool. I chose the appropriate iso and the appropriate usb. I successfully format it without errors. Then i put the usb in my desktop and boot up to my BIOS. I choose the usb as my boot drive, then boot. I get a black screen for a while (3-4 seconds) then it boots to windows (my primary HDD).
2) see 1 except i didnt format the usb... same results.
System:
fx 4100
radeon 6850
8 gb gskill ram
500 gb hdd
asrock extreme4 970 mobo
Help would be greatly appreciated, i and foaming at the mouth with anticipation of this SSD
4 answers Last reply Best Answer
More about cant create bootable drive power
  1. bump please
  2. use these and it will work i was useing power iso and had same problems doesn't work for booting for some reason http://www.microsoftstore.com/store/msstore/html/pbPage.Help_Win7_usbdvd_dwnTool
  3. use this it will work fine http://unetbootin.sourceforge.net/
  4. Best answer
    Microsoft one is better why use unet booting when its literally a 1 click install with Microsoft own usb booter prog and works for any version of windows
Memory ISO Power USB
