3D Monitor or BIGGER monitor for dual-LCD setup?
Hello everyone,
I currently have dual-monitor setup with a Hannspree 28" 1920x1200 as my primary and a Samsung 20" 1600x1200 in portrait orientation as my secondary. Sadly, my Samsung is on its way out, so it's time for a new monitor.
My initial thought was to get a second 28" Hannspree, since I'd get identical color properties and I wouldn't have to deal with annoying resolution scaling and different panel heights when I drag a window from one screen to the next. However, I'm starting to consider getting a 22 or 23 inch 120hz LCD instead, with a 3d vision kit from nVidia. I have 2 GTX 480s in SLI, so it's definitely tempting...
The second 28" would cost me $275-$300, and the 22"-23" 3D monitor with the glasses kit would set me back almost $400. I'm having a hard time justifying an extra $100 for a significantly smaller panel, especially when I don't know if 3D gaming (or at least nVidia's present version) is a gimmicky, headache inducing fad that will leave me with a fancy monitor and few games to use it with. So, what would you do? Is 3D worth it?
8 answers Last reply
More about monitor bigger monitor dual setup
  1. As an owner of the Hannspree, I would rather have two of them than a 3D monitor. After seeing a 3D movie recently, I wouldn't want anything 3D.
  2. ^If In my own experience, no, 3D is not worth it. I have both 3 monitor set-up & 3D setup on 3D TV. I use the 3-monitor setup for gaming 99% of the time.
    You will be better off with investing in 3 monitor set-up & play surround vision. It will even have more value for productivity. But of course you have to spend around $550 to $600. But what the heck? You got 2x480 so I'm sure you can afford it. :)
  3. Hehe, I wish I could afford it. I'm starting college in 2 weeks, and money is going to be tight. I got the 480s in a robotics competition :D The $400 3d setup would be pushing it, which is why I want to know if it's REALLY worth it.
  4. ^That's too bad.
    But anyway, I stick to my opinion that its not worth it. I have the 55" Samsung C7000 3D TV and I can not get myself to play 3D on it for long time. The game is stunning to look at but to play long period at a time is not comfortable with the heavy 3D glasses pressing on my nose (unfortunately, I have to wear the 3D glasses over my eyeglasses) and strain in my eyes. I prefer to watch movies which last 2hours on average and it doesn't strain my eyes & my nose as much.
  5. Do you find that the constant re-focusing due to the depth of field produces eyestrain? Or is it just the discomfort from the glasses themselves?
  6. The Hannspree 28" is fairly old tech. Still uses a CCF backlight, and has a fairly wide bezel which does impact side by side viewing a little.
    I would look for a more current generation 24-28" monitor if I was buying one now and use the current Hannspree as the secondary monitor.
  7. The one issue I have with that is that the Hannspree has a 1920x1200 resolution, and pretty much every other 28" LCD I've found in the same price range has a 1920x1080 resolution. Does anyone know a 28" led backlit monitor with a 16:10 aspect ratio that doesn't cost a fortune?
    It may be. Looking at games even in just normal screen is already eye straining with constant changing of scenes as you move the mouse around. If you are in a fight, the screen movement is even more & your eyes need to focus & refocus. The 3D just add to that...
Nvidia Dual Monitors Monitors 3D Graphics Product
