$1400 gaming PC. Need help/advice on components and price
Last response: in Systems
Approximate Purchase Date: In the next two to three months
Budget Range: 1600 Before Rebates (would like to be 1300 to 1100)
System Usage from Most to Least Important: Gaming, School, Videos
Parts Not Required: OS
Preferred Website(s) for Parts: Newegg.com
Country of Origin: United States
Parts Preferences:I would like to use Intel CPU and Nvidia Graphics Card
Overclocking: Maybe
SLI or Crossfire: No
Monitor Resolution: 1080i or higher
Additional Comments: I would like it to be quiet. Also I would like advice on the parts in using and see if i could cut down the price. This is my final draft.
Screen: SAMSUNG T24A350 ToC Rose Black 24" 5ms Full HD LED BackLight LCD Monitor w/ DTV Tuner 250 cd/m2 DC 1,000,000:1 (1,000:1) http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Graphics Card: GIGABYTE Super Overclock Series GV-N570SO-13I GeForce GTX 570 (Fermi) 1280MB 320-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card http://www.newegg.com/Product/Prod [...] 6814125382
Motherboard: ASRock Z68 EXTREME4 GEN3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Ram:Corsair Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CML8GX3M2A1600C9B http://www.newegg.com/Product/Prod [...] 6820233196
Case:Corsair Obsidian Series 650D (CC650DW-1) Black Steel structure with black brushed aluminum faceplate ATX Mid Tower Computer Case (with Sony Optiarc CD/DVD Burner Black SATA Model AD-7261S-0B LightScribe Support - OEM) http://www.newegg.com/Product/ComboDealDetails.aspx?Ite...
Power Supply:COOLER MASTER Silent Pro M700 RS-700-AMBA-D3 700W ATX12V V2.3 SLI Certified CrossFire Ready 80 PLUS BRONZE Certified Modular Active PFC Power Supply http://www.newegg.com/Product/Prod [...] 6817171037
CPU: Core i7 2600 LGA 1155 Boxed Processor http://www.microcenter.com/single_product_results.phtml...
HDD: SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive http://www.newegg.com/Product/Prod [...] 6822152185
SSD: OCZ Vertex Series OCZSSD2-1VTX30GXXX 2.5" 30GB SATA II MLC Internal Solid State Drive (SSD) http://www.newegg.com/Product/Product.aspx?Item=N82E168...
HeatSink: COOLER MASTER Hyper 212 Plus RR-B10-212P-G1 "Heatpipe Direct Contact" Long Life Sleeve 120mm CPU Cooler Compatible Intel Core i5 & Intel Core i7 http://www.newegg.com/Product/Prod [...] 6835103065
Thank you for your input it is much appreciated!
Get the i5-2500k
Not a fan of cooler master PSUs. Get one from Antec, Corsair, XFX or Seasonic.
For case, I'd prefer this: http://www.newegg.com/Product/ProductList.aspx?Submit=E...
SSD is too small. But I think you're planning to use it as a cache? So that's fine I guess.
EDIT:
This PSU is good, and has a promo code
PC Power and Cooling Silencer Mk II PPCMK2S650 650W ATX12V v2.2 / EPS12V SLI Ready CrossFire Ready 80 PLUS SILVER Certified Active PFC Power Supply
$20 off w/ promo code EMCKAHH42, ends 9/28
$89.99 less $20 promo code, and an additional $20 MIR. Comes out to $49.99 with free shipping. You won't find any other Silver certified quality PSUs close to this price.
Ask the community
