Sign-in / Sign-up
It not overclocking now......HELP!!!
  • Motherboards
  • Overclocking
  • Processors
October 14, 2012 12:32:24 PM
Hi Guys,
I have an Asus p5g41t-mlx motherboard running with Intel Dual Core 1.8 Unlocked processor.
I was overclocking it to 2.57 GHz and it was running fine as Core Temp was 55 Celsius. But after updating my BIOS, its not getting up from 2.35 GHz.
Need your expertise on this..Plz Help!!!
System Specs:
Asus Mother Board = P5G41T-MLX
Processor = 1.8 GHz Dual Core
RAM = Corsair Value Select 2GB 1333 MHz
HD = Segate Barcuda 500GB
Graphics = 9400GT
More about : overclocking
a c 77 V Motherboard
a b K Overclocking
October 14, 2012 2:55:03 PM
this is pretty old. id actually just suggest getting a completely new rig. also, there wont be a big difference from 2.35ghz and 2.57ghz just saying.
you could try to downgrade the bios to the original
m
l
October 15, 2012 1:37:39 PM
This is my separate system. The rig i use for my self, you can see the configuration in my profile, eg I7 37770K, 560GTX, Maximus V Gene etc.
I tried to downgrade BIOS. But failed.
What i can do else?
m
l
