Hi.I recently bought some aftermarket fans for my pc. Cause my M3A78T runs hot at 52-53 under load.
My specs are Phenom II X4 940,M3A78T,8 GB RAM,GTS 250, Chieftec 650W, WD 500AAKS SATA and the case is a silverstone precision PS02.
So i bought these fans COOLERMASTER R4-BMBS-20PK-R0 BLADE MASTER FAN 120MM 2 of them.
These fans have a 4 pin connector.The three connectors of my M3A78T are all 3 pin(cha_fan1,cha_fan2 and PWR Fan.)
When i install my new coolermaster fans to any of these 3 pin sockets,the fans work at 100%.They offer a considerable good airflow for a 120mm fan(76,8CFM) and lower my mobo temp at 43 under load.However the noise in unbearable.
I tried to use speedfan but althought i have a pc since 1995 i cannot make it work correctly.(specifically i cannot link the pwm indicators at speeds tab to the apropriate fan installed at my pc)
I tried to use 3 to 4 pin adaptors but it didn't worked.The fans remain idle or made sporadic movemets and then stopped.
Can anyone help?any idea??
Thanks in advance and sorry for my poor english.
