I put the components listed below together and used an old dell VGA LCD monitor 15" I had laying around and when I plug it in, the power light on the monitor goes from green to orange (asleep). Then when I turn the computer on the monitor doesn't wake up. Is there a step I am missing to set up the video card?
I checked all the power to the mother board - which turns on fine and powers the cooler and the video card (fan is moving). THe power to the CPU is in check, I verified the CPU was ok - there were no bent pins, I re-seated the video card and tried the other PCI-E 3.0 slot. I re-seated the RAM and also tried to get the bios to come up with one stick of RAM. I removed the hard drives and the wireless/bluetooth card to see if something else was causing a problem.
Any insights would be helpful - again, am I missing a step after I get everything assembled? Do I need to load flash the CMOS or load something for the video card? I did ensure that the RAM was in the correct slots (4&2,1&3). Also the box for the MB said BIOS 7 and above so I'm not sure what version of the BIOS I have but Gigabyte says I need F8 for the i7-3820. How can I confirm the version of the bios? Is there a way to hook up the monitor bypassing the video card? I'm totally stuck.
Also Gigabyte says I need @Bios to update the bios to F8, but I can't even get the machine to POST anything to the monitor.
Thanks!
Tim
case: Corsair 500R
SanDisk Extreme SSD 120 GB SATA 6.0 Gb-s2.5-Inch Solid State Drive SDSSDX-120G-G25
http://www.amazon.com/SanDisk-Extreme-Gb-s2-5-Inch-Solid-SDSSDX-120G-G25/dp/B006EKJCWM
GIGABYTE GA-X79-UD5 LGA 2011 Intel X79 SATA 6Gb/s USB 3.0 E-ATX Motherboard
http://www.amazon.com/gp/product/B0064Z6Y9G
Corsair Vengeance 32GB (4x8GB) DDR3 1600 MHz (PC3 12800) Desktop Memory (CMZ32GX3M4X1600C10)
http://www.amazon.com/gp/product/B0068ZWZY0
Noctua NH-D14 SE2011 Quiet CPU Cooler for Intel LGA 2011 Socket with 6 Heatpipes, 140/120mm SSO Bearing PWM Fans NH-D14 SE2011
http://www.amazon.com/gp/product/B00631QFG8
Corsair Professional Series AX 750 Watt ATX/EPS Modular 80 PLUS Gold (AX750)
http://www.amazon.com/gp/product/B003PJ6QWE
Intel Core i7-3820 Quad-Core Processor 3.6 GHz 10 MB Cache LGA 2011 - BX80619I73820
http://www.amazon.com/gp/product/B006YM9JSW
EVGA GeForce GTX670 2048MB GDDR5 256bit, 2x Dual-Link DVI, HDMI, DP, 4-Way SLI Ready Graphics Card (02G-P4-2670-KR)
http://www.amazon.com/gp/product/B007Z3HZIA
Already Owned:
WESTERN DIGITAL, Western Digital Caviar Blue Desktop WD2500AAKX 250 GB Internal Hard Drive
http://www.amazon.com/WESTERN-Western-Digital-WD2500AAKX-Internal/dp/B0050R0DN2
Dell E157FPF - Grade B - 15" LCD Monitor Black
http://www.amazon.com/Dell-E157FPF-Grade-Monitor-Black/dp/B006FNCMGQ/
Thanks!
Tim
case: Corsair 500R
Already Owned:
