I am not someone who just went and got the first parts I saw, I've researched countless hours on Processors, graphics cards etc, but i still need some guidance on the final selection of a few parts.
Motherboard
GIGABYTE GA-990XA-UD3 AM3+ AMD 990X SATA 6Gb/s USB 3.0 ATX AMD Motherboard (140$)
(This is a good one to choose right, there isn't anything better for less is there?)
CPU
Bulldozer 8 core FX-8120 clocked at 3.1GHz and boosted to 4GHz 185$
RAM
Kingston KHX1600C9D3B1 4GB DDR3 RAM @ 1600 ($29) (going to get a second stick later for 8gb)
Video Card
Radeon 5850 (140$, 120 after rebate)
Hard Drive
Seagate Barracuda 1TB (Sata 6) ($55)
DVD Burner
Asus DRW-24B3ST/BLK/G/AS Internal 24x CD/DVD Drive ($25)
or
ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - Bulk - OEM 19$
Case
Not sure at all. I want something around 50$ that would look decent if I got green LED fans.
Power Supply
OCZ ModXStream Pro Power Supply 600-Watt ($60)
Unless you can suggest a better one for the price.
Is there any changes I need to make, any incompatibilities?
Also, if someone wouldn't mind explaining how front panel ports work on a case, do they connect to the internal IO ports in your motherboard?
Motherboard
CPU
RAM
Video Card
Hard Drive
DVD Burner
or
Case
Power Supply
