New system, will this work?
I want to build this machine, I already have a HDD, dvd drive.
AZZA Hurrican 2000 CSAZ-2000 Black SECC Japanese Steel ATX Full Tower Computer Case
2x GIGABYTE GV-R695OC-1GD Radeon HD 6950 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP in crossfire
COUGAR CMX 1000 COUGAR-1000CMX 1000W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS BRONZE Certified Modular Active PFC
AMD Phenom II X4 975 Black Edition Deneb 3.6GHz Socket AM3 125W Quad-Core
CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600
ASUS M4A89TD PRO/USB3 AM3 AMD 890FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard
CORSAIR H80 (CWCH80) High Performance Liquid CPU Cooler
Win 7 64bit home premium
Im jsut curious because the GPU's are for pci express 2.1 and the mobo is only express 2.0.
Just want to make sure that this will all work.
6 answers Last reply
More about system work
  1. That would work
    but you should not build it .
    Use am AM3+ motherboard with a 970 or 990 series chipset so you can upgrade to future processors .
    Buy the 955 phenom and overclock it to 975 speeds and beyond .
    Make sure your RAM is 1.5 volt .
    PCI-e slots are backward compatible . You have no worries there
    The psu is probably junk . Never even heard of cougar .
    Corsair , antec, seasonic , enermax all good . You need about 750 watts , maybe 850
    Then you are set
  2. u think 650 can handle both cards?
  3. and what do u meen i shouldn't build it?
  4. will the AM3 processor work on the AM3+ board?
  5. Yes AM3 will work on AM3+.. Outlander told you all you need.
  6. As far as PSUs are concerned, be informed. Before you buy any PSU read accurate, objective PSU reviews at reputable sites such as www.jonnyguru.com or www.hardwaresecrets.com on the EXACT model PSU that you are interested in as some brands have good and poor quality PSUs.
    You can also get an accurate rating of how much PSU power is required for your current or future system at the PSU calculator link below. Once you know the total PSU watts required then you need to confirm that the 12v rail has enough amps. to support your Vid card(s) and the rest of the PC system.
    There are several websites that show the Vid card power consumption in watts. Divide the watts by 12 to determine the amps. required on the 12v rail(s). Add 15 amps for the rest of the PC on the 12v rail and you now know the Minimum total 12v rail amps required under full load. It's best to have at least 5-10 amps. reserve on the 12v rail available under full load so the PSU is not loaded to 100%.
    It's also worth noting that people often misunderstand the 80% power rating. This is a rating of the PSU's energy efficiency not it's output. 80% plus PSUs use less grid power to produce the same PC power. If it's 80% Bronze, Silver or Gold the cost savings on electricity is pretty small between Bronze, Silver and Gold unless you are paying very high rates for electricity so any 80% rated quality PSU is fine even if not Gold. For those who leave their PC on 24/7 a quality 80% PSU is a good investment.
    http://extreme.outervision.com/psucalculatorlite.jsp
    http://www.guru3d.com/article/geforce-gtx-560-ti-sli-review/14
    http://www.techpowerup.com/reviews/NVIDIA/GeForce_GTX_560_Ti/25.html
New Build Systems
