Hi,
I have a little problem and I asking for your help.
I just started for weeks ago to play with some games.
I had a ATi HD 4770 (512mb)... and this card seem to be a bit slow in Duke Nukem Forever.
I know my pc is kinda old... but it's a Duo Core 2 2.4ghz... so he should at least be playable at low resolution. (also I don't have many program running... I keep my Windows clean Hijackthis and disable unused Windows services).
I had older ATi Cataclyst drivers.. so I tried uninstall drivers... few test.. installed the lastest 11.6.
Seem the card run faster without any Cataclyst drivers.. ?!? I don't really understand why...
I also had trouble with Flash running slow. Many topic exists for this issue with 4770 and 5770. (I think it's due to clock speed in Windows / The card is underclock at 200-250mhz in Windows so doesn't give the correct hardware acceleration)(anyway this is another issue)
Also I seem having trouble with nProtect (game antihack in few games). Slow performance and game freeze (Game???.des could freeze the game for 1-2 minutes in the middle of a in game 3D shooter.. it's not good )
Anyway... I just choose to change the old card for an "EVGA SuperClocked 01G-P3-1563-AR GeForce GTX 560 Ti (Fermi) 1GB 256-bit". This card should be at least 2 times better.
I uninstalled ATi.
Change the card.
Install Nvidia drivers.
Run DNF... somewhat same slow performance... ?!?
Running Flash game, a bit better but still suc*s.
I have another computer with an low level msi nvidia (I think its a 8400) and it's better than that....
Finally, I want your idea for troubleshoot this...
Perhaps you know what is wrong...
I think I have a hardware or Windows 7 problem.
This is my hardware:
-Intel Core 2 Duo E6600 2.4ghz
-ASUS P5QL/EPU LGA775 P43 chipset FSB 1600(O.C.) Energy Saving
-OCZ Gold XTC 0CZ2G10664GK 4GB 2x2GB DDR2-1066 5-6-6-18
-500GB WD Caviar Black WD5001AALS 7200rpm 32MB
-4 others HD
-LG BD-RE WH10LS30
I think nothing should be wrong... except:
1. The CPU... (but he should be playable at low resolution)
2. if ASUS P5QL/EPU have special trick in the bios?
3. Perhaps having many SATA II drives overload the motherboard (since I use all 6 SATA ports)?!?
And for the software... I just see Windows 7 64 bits Pro SP1.
1. I run every update since Win 7 release. Perhaps it's a problem ?
I think about test few thing more.. but want your opinion before do extreme thing... like remove hds or reinstall windows, perhaps XP 64bits or Vista 64bits ?
What I thinking right now:
-Remove all hds except Windows 7 disk and check performance.
-If it's still wrong, "Build a Virtual PC" (but I don't know if I lose performance there) or just change the windows 7 disk for a empty one and reinstall (i don't know which version) Windows 64bit.
Could you help me?
I uninstalled ATi.
Change the card.
-4 others HD
-LG BD-RE WH10LS30
Could you help me?
