Hey guys, just installed a Z77 Extreme4 ASRock motherboard along with a new i5 and new memory - everything boots up and works fine (But no bootup beep - odd...it's built in but I'm not sure if it's just a setting or something). Anyway, I tried using Sysprep to tell my HD with windows 7 on my old EVGA motherboard to basically forget all the drivers and such so I could cleanly install my ASRock. Welp...don't ever do this because it doesn't work. I go to boot up and it tells me it can't launch and will finish setup after reboot. Ad infinitum...I tried using the Windows 7 disc to repair it, but here's the interesting bit - my USB mouse and keyboard which work FINE when I'm in UEFI and operating the other motherboard menus all die as soon as it shows the Windows 7 setup screen.
So I pulled out a PS/2 keyboard to use (Thank goodness the motherboard at least has ONE PS/2) - but I'm seriously concerned, why is this happening? Please don't tell me this is signs the motherboard is bad...I just bought it, but I don't want to have to go through that RMA process. I could've imaged my hard drive on my new 1 TB...if it wasn't head clicking and I just RMA'd it. Everything seems to work fine until I get to that cursed Windows 7 disc setup screen. Is it possible this is just an issue that will resolve itself after I fix my Windows 7 install, or is this new motherboard already defective? I have all USB legacies and versions enabled in UEFI. My USB devices are a USB keyboard (Logitech G15), USB mouse (G500), and a MIDI keyboard which is powered off (M-Audio Oxygen 61).
Also, if anyone has any ideas on a way to salvage my Windows 7 install please let me know. I have ways to access the drive from other PCs so I can attempt repair in that manner. I really do not want to format the drive if avoidable, I purposely didn't buy an SSD because it would require a format and reinstall. If I have to do this, not really a benefit to me having not done that in the first place...
