Wireless lag when gaming - Please help
Playing Yahoo games w/ my pc connected to Verizon Wireless MyFy, it freezes maby 20 times during a game.
Is it is going dormant? if so how to fix? (Because if i run TDAmeritrade Streamer in the background it NEVER freezes)
2 answers Last reply
More about wireless gaming help
  1. Ideally don't use wireless. Wireless is usually about half the speed of wired even with good wireless reception.
    You should try to optimise your reception and avoid interference.
    1) raise the router above furniture level
    2) Experiment with channels (some will work better or worse depending on your environment)
    3) If you can detect strong neighbouring wifi, use a channel at least 5 stops away from strongest.
    4) Relocate cordless phone base or video sender etc.
    5) Be prepared to move the computer (or at least turn it so your body is not between the router signal and the wireless adapter's antenna).
  2. It's speed is 3500kbps my other option is dialup at 37kbps! The TDAM streamer uses Java, the same as yahoo games, if i use java in the background the games NEVER freeze! WHY???
Wireless Gaming Wireless Networking
