Will this system work?
Hi guys im building my second system, i still dont know alot about parts and what graphics cards will fit in the case and so on as my mate helped me with the majority of the build. This is my first pc and what i have in it at the moment -
THERMALTAKE V3 BLACK 120mm Case Fan WINDOW 450watt POWER Model: VL84521W2A -$77
AMD Athlon II X2 260 Dual Core 2meg CACHE 3.2Ghz Socket AM3 -$69
ASUS M4N68T-M V2 nVidia nForce 630A Intergrated Video DualCh DDR3 1800Mhz (OC) 8Channel HDAudio -$55
Western Digital 500 gig 7200rpm SATAII YX RE4 64meg Cache CAVIAR BLACK Model: WD5003ABYX -$78
SAPPHIRE HD5670 1GB GDDR3 DVI / HDMI / D-Sub -$75
KINGSTON Twin Pack 2x4 gig (8gig Total) DDR3 1333Mhz (PC3-10600) -$75
Thats pretty much the lot except for monitor keyboard and the other crap. Here is the link to my checkout(see if it would be ok), i would like as much feedback and help as possible. Thanks guys
http://www.pccasegear.com/index.php?main_page=shopping_cart&sort=20a
please let me know of anything i have missed.
6 answers Last reply
More about will system work
  1. why are you buying such an old cpu.its too weak in performance.
  2. Your link doesn't show anything. It says "Your Cart Is Empty".
    Yes, with the components your mentioned, your system would work.
    Thanks.
  3. you can get an Athlon IIx3 455 Rana 3.1GHz for $74.99. Thats a lot better cpu that what you have, and if you are gaming, you need a better PSU and a better GPU...Old hardware for a "new" system.
    That list of hardware is my current system about 18 months old or so.. i will post seperate links to the new parts this is what i need help with, all help will be sweet
    This is the stuff im looking at buying now
    the case - http://www.pccasegear.com/index.php?main_page=product_info&cPath=25_238&products_id=15091
    the cpu - http://www.pccasegear.com/index.php?main_page=product_info&cPath=187_345_1261&products_id=12293
    the motherboard - http://www.pccasegear.com/index.php?main_page=product_info&cPath=138_1207_803&products_id=17500
    the HDD - http://www.pccasegear.com/index.php?main_page=product_info&cPath=210_344&products_id=16853
    the power supply - http://www.pccasegear.com/index.php?main_page=product_info&cPath=15_1082&products_id=5384
    the memory - http://www.pccasegear.com/index.php?main_page=product_info&cPath=186_538_913&products_id=13931
    If there is anything i am missing please let me know and if i can get better parts that are cheaper would be good aswell as i said its my second pc but i have had a lot of help with my first build
Homebuilt Systems Product
