Hello Everyone,
I will be mounting 4 Cooler Master Excalibur R4-EXBB-20PK-R0 120mm Case
Fans in a push pull configuration on a Corsair H100. All 4 fans will be plugged into
the CPU_Fan and the CPU_Opt_Fan connections on the P9x79 Pro via two Gelid
Solutions Model CA-PWM 350 mm PWM Y Cable Splitters.
So, 2 fans in each connection. I want to be sure that the connection can handle both
fans. Here are all the power details of the fans and P9x79 Pro that I can find:
A single Cooler Master Excalibur:
Voltage: 12 V DC,
Current (Ampere): 0.45A Max.,
Power consumption: 6 W Max.
Each CPU Fan connection on the P9x79 Pro:
Supports a maximum 1A (12 W) fan power
Can I put 2 of the Cooler Master Excalibur fans on a single CPU Fan connection of
the P9x79 Pro?
Is it safe? Am I pushing the limit of that connection too far?
I have already asked Asus and they took the 'no liability' way out and said they do not know. So here I am...
Details of Build:
Corsair 650D Case
Asus P9x79
Pro Intel i7-3930K
G.SKILL Ripjaws 16GB DDR3 2133
EVGA GeForce GTX 680 FTW+
Corsair HX1050
Corsair H100
1 Corsair AF120 Quiet Edition 120mm Fan
1 Cooler Master 200mm 120mm
4 Cooler Master Excaliber 120mm Fans
2 Samsung 830 256GB SSD - Raid 1
2 Samsung F4 2TB HDD - Raid 1
1 External WD 2TB
I will be using this PC for everything from Video editing, Gaming, to processing massive amounts of Tick Data for use in the Forex Market....a little of everything.
Thank you for your time,
Logic
Voltage: 12 V DC,
the P9x79 Pro?
Details of Build:
Corsair 650D Case
Asus P9x79
Pro Intel i7-3930K
Corsair HX1050
Corsair H100
1 External WD 2TB
Logic
