Solved
I have a motherboard compatibility problem :0
Best solution
USB 3.0 is backwards compatible with USB 2.0, meaning you can connect the USB cable in the case with the USB 3.0 headers on the motherboard, but the speeds will only be the speeds of USB 2.0 (maxing @ 480mb/s)
Ask the community
