Hi, two days ago I upgraded cpu, mobo, ram and psu on my pc. The problem is, I can´t reinstall windows because of constant reboots and BSODs. I decided to do a test with MemTest, and turns out it throws thousands of errors! I tried with both the ram modules, separately and in different sockets. All with the same result. I called my provider for memory RMA, but then I thought that getting both bad rams at the same time was TOO unlikely, so I think it must be something else, like the motherboard. I checked the BIOS and it is running the correct settings for the memos. I also checked my MOBO memory support list, and it shows the exact model of my memory. I´m very confused. I´ll try to change the memories tomorrow but I don´t think It´ll solve the issue. Getting 2 memories, and both being faulty? Sounds weird. I hope someone could help me. Here are my specs:
CPU: Intel i7 2600k
MOBO: Gigabyte GA-Z77X-UD3H
RAM: 2x AMD 4gb DDR3 1600MHz Entertainment Edition AE34G1609U2-U
PSU: Coolermaster Silent Pro 600w.
CPU: Intel i7 2600k
