Hello! I am having some PC issues that I was hoping you all could help me solve. Here are my PC specs (if you need any other info please let me know)..
Dell Studio 540
Intel Core 2 Quad Q6600 @ 2.4GHz
8.00 GB RAM Memory
NVIDIA GeForce 8800 GTS
ACPI x64 based
PSU: LiteOn Model # PS-6351-2 350W
BIOS:
DELL, INC
VERSION: 1.0.6
11/03/2008
I purchased this pile a couple of years ago. In the past year the GPU began giving me lots of issues. It worked intermittently for a while but eventually crashed my computer, and I could no longer start up without blue screens. I tried for a while to fix it but eventually I decided to bake it in the oven via some instructions I found on the internets. Didn't sound smart but I had nothing to lose. It actually worked fine for a few months after the baking before crapping out again. Around the time it crapped out the second time, my computer also stopped powering up. I found that by unplugging everything and trying it would sometimes work. I did try uninstalling and reinstalling the RAM for some reason based on other internet answers and that didn't seem to help. In case you haven't guessed I am not a computer guru by any means. At this point the PC is on but I can't turn it off for fear that it won't start up again. Also the way I made it work graphically was going into safe mode and disabling the GPU.
If you read all that then thank you. I have about $250 to spend to get this puppy going again if possible. Here are the parts I found based solely on research that may be outdated or plain wrong (interwebs). Stick with me, the questions themselves are coming..
New Case (Antec 300) http://www.newegg.com/Product/Product.aspx?Item=N82E16811129042
New PSU (XFX PRO550W) http://www.newegg.com/Product/Product.aspx?Item=N82E16817207013
New GPU (MSI Radeon HD6850 Cyclone) http://www.newegg.com/Product/Product.aspx?Item=N82E16814127576
Questions time!
1. Is there anything else you would try to fix my PC before buying these?
2. Are all of these parts necessary (ie can I fit the new PSU in my old case or should I just get the new one)? Any areas I can cut costs are a-ok with me.
3. Are the parts listed going to fit my PC, and will I be able to swap all the parts into the new case by following instructions on the internets? I pride myself on my internet instruction following abilities but any tips would be appreciated.
4. Are the parts actually any good or do you have another suggestion in the price range?
Any answers to these or any helpful hints are greatly appreciated!
Dell Studio 540
8.00 GB RAM Memory
ACPI x64 based
BIOS:
DELL, INC
VERSION: 1.0.6
11/03/2008
Questions time!
