I've got an old power supply FSP500-60GLN. I use 2 molex > 6 pin connector to power a videocard, which leaves no free molex. I've had 8800gt and 250gts. The latter died a few days ago so I need to get a new one. I'm thinking of buying 560 ti or 460 although they both require 2 6 pin connectors, which I don't have. (only one) It's probably a bad idea but I wanna make sure. How about using a couple of splitters (MOLEX > MOLEX x2) to get 2 6 pin connectors for a videocard?
Or should I think about getting some other videocard? 550 ti maybe ? What's the best videocard I can get in my situation ?
I'm not going to buy a new power supply.
2,4 Duo
2 gb ram
Asus P5b-E
3 HDD SATA
DVD RW nec
2,4 Duo
2 gb ram
Asus P5b-E
3 HDD SATA
DVD RW nec
