Solved
New build problem
Just built my 2nd pc a little over 1 month ago, everything been working great but now I am experiencing a odd problem has happened twice once last week when I tried playing WoW, then today just by clicking on a video file display goes dark, so far by restarting pc it fixes the problem what could be causing this? If it's the video card have had it replaced already because previous one died.
System
Case HAF X
Memory F3-12800CL9Q-16GBXL
M/B GA-Z68XP-UD3P
i5-2500k
Corsair CMPSU-750HX
Evga GTX 470
4 answers Last reply Best Answer
More about build problem
  1. So you were playing WoW and the screen went black? And you opened a video file and the screen went black?
    What do you mean by go black? Was the monitor getting a signal still, or was there a message saying no signal?
    Did you try to Ctrl-alt-del at that point?
    Yea it was still getting a signal, nope didn't think of trying to Ctrl-alt-del.
  3. Best answer
    Have you connected power to both power connections on the video card? I'm guessing yes since this is a fairly rare problem.
    Remove the RAM from channel 2 and just run with 8GB for a while, see if that helps. If so swap out the RAM for the other pair and see if that also runs stably.
    The first step is always to try to produce the issue on demand.
    http://www.tomshardware.com/forum/forum2.php?config=tomshardwareus.inc&cat=31&post=292686&page=1&p=1&sondage=0&owntopic=1&trash=0&trash_post=0&print=0&numreponse=0&quote_only=0&new=0&nojs=0
    There's some resources.
    CPU-Z
    Prime95
    HWMonitor
    memtest86+
    Furmark
    That's a good list of things you'll need to sort it out. If you can reproduce the crash with Furmark for instance, you have a starting point.
  4. Best answer selected by Bi0hAzArD.
New Build New Build Systems
