Hey guys,
So I'm looking to purchase a 32GB kit of DDR3 1866 (or possibly just 1600mhz) for my desktop which I use for gaming and video editing. I know that this amount of RAM is overkill for most applications, but I will utilize it for video editing. Specifically, I will be creating a large ramdisk for some 1080p video projects I have. Anyways...
I have been searching and came across these:
G.Skill Ripjaws X http://www.newegg.com/Product/Product.aspx?Item=N82E16820231562&name=Desktop-Memory
G.Skill Ares http://www.newegg.com/Product/Product.aspx?Item=N82E16820231561&name=Desktop-Memory
G.Skill Sniper http://www.newegg.com/Product/Product.aspx?Item=N82E16820231612&name=Desktop-Memory
G.Skill Ripjaws Z http://www.newegg.com/Product/Product.aspx?Item=N82E16820231529&name=Desktop-Memory
Basically, I have read in my search that the difference between the branding is usually the timing, speed, or voltage... but they're all the same. I understand that some of them are quad-channel vs. dual-channel kits, but other than that, am I just picking the best color???
Putting these in an Asus Sabertooth 990FX AM3+ board. Also, I know that my CPU is restraining the ram speed at the moment, but I will also be upgrading when the Vishera CPUs are released.
