Help with newly built system
jack-knife
13
CPU: i7 2600K @ 3.40GHz
GPU: Gigabyte GeForce GTX 570 1280MB Overclocked V2
Mobo: ASUS P8Z68-V Pro Motherboard B3
RAM: G.Skill DDR3-1600 8GB Dual Channel [RipjawsX] F3-12800CL8D-8GBXM
PSU: Seasonic S12D 850W Power Supply
Case: Antec Dark Fleet DF-85
SSD: OCZ Vertex 3 60GB
HDD: Western Digital Caviar Black 1TB SATAIII
There are the specs for the rig I built today. When I hit the power button all the fans spin up and it all gets going and then ten or so seconds later it powers off and restarts. I get no display and USB devices don't power on. Every time I hit the reset or power buttons, the CPU light goes on and off (is this supposed to happen?)
Also I can't find the cable for the internal speaker inside my case to plug into my mobo.
Any help would be appreciated.
jack-knife
13
Okay, so something is preventing my system from booting up. I have no internal speaker to figure out what. I'm checking for shorts on the mobo and I doubt that it's the RAM cause the ASUS MEMOK! light comes on.
Any other suggestions?
