Yes No
Ads
Tom's Hardware > Forum > Systems > New Build > New Silent AMD Build Opinions/Rating
Forum Systems : New Build New Silent AMD Build Opinions/Rating
Want to get peoples opinion on my new build. It will be my 2nd overall build. I am building it for silence, light gaming, and video editing. I do like AMD cause it seems I can get more for the punch. I guess you can say I am an AMD fanboy. I will at some point do SLI and will try to OC for the first time as well. Already have two 2tb Hitachi 6GB/s 7200rpm Deskstars as my media storage drives.
CPU: Waiting on Bulldozer release. Will get the FX8120....$205.00
PSU: COOLER MASTER Silent Pro M600w....$69.99 after MIB
http://www.newegg.com/Product/Prod [...] 0pro%20600
Mobo: Gigabyte 990FXA UD3....$139.50
http://www.newegg.com/Product/Prod [...] 6813128514
GPU: Gigabyte GV-N550OC-1Gl.....$99.99 after MIB
http://www.newegg.com/Product/Prod [...] 0gtx%20550
Case: Fractal R3 Define Titanium Gray....$109.99 + $19.99 shipping (uggh)
http://www.newegg.com/Product/Prod [...] 6811352004
HSF: Noctua NH-U12P SE2....$54.99 + $5.99 shipping
http://www.newegg.com/Product/Prod [...] 6835608014
Memory: G.Skill 1.25v Sniper Low Voltage 8GB (2x4GB) DDR3 1600...$49.99
http://www.newegg.com/Product/Prod [...] 6820231461
Case Fans: 4 x Open Box, Scythe SY1225SL12L 120mm "Slipstream" Case Fan (10.7 dBA)....$19.96
http://www.newegg.com/Product/Prod [...] 6835185057
Blu Ray Reader: Open Box, SAMSUNG Black Blu-ray Combo SATA Model SH-B123L....$35.99
http://www.newegg.com/Product/Prod [...] 6827151222
SSD: Any suggestions, really want one to run my Windows 7 OS. Would like to keep it between 50-90 USD.
Total: $811.38 + SSD
Message quoted 2 times
Message edited by red46123 on 10-01-2011 at 07:16:25 AM
Reply to red46123
A couple of dollars more for the Antec P183 v3
http://www.newegg.com/Product/Prod [...] 6811129174
but worth the extra.
It wont need additional fans , but you can add a couple at the front of the mb chamber and they will lower temperatures a little .
If you are "light gaming" why bother with SLI ?
A single card can do all you need , and its almost always better to buy a single newer card , than another older partner to the one you own .
The Asus M5A97 evo
http://www.newegg.com/Product/Prod [...] 6813131757
Saves you money now that you can spend on the SSD
http://www.newegg.com/Product/Prod [...] 6835185168
is a very good and very quiet cpu cooler
Message edited by Outlander_04 on 10-01-2011 at 01:54:50 AM
Reply to Outlander_04
The Asus M5A97 evo
I had to think long hard between the Antec P183 and the Fractal. Right now I have a Antec Sonata case which I hate say is not really well engineered. I like the sleek look of the Fractal R3 and it has comparable reviews to the P183. I guess I do more then light gaming. However, the current card is rated excellent for quiet and low power comsumption (= less heat/less fan noise). I don't need a world beater that screams/produces a lot of heat for what I do . Also, the Scythe Mugen 3000 was my 2nd choice but I like the Noctua NH-U12 cause of its build quality, silence, warranty, and coming with two top notch fans for a push/pull configuration. Was about to get the Mugen but for $10 bucks more I went with the Noctua. I guess what it came down to was personal preference. Definitely valued opinion thanks. Will check out the mobo instead of the UD3. I guess your right their. Save me a little money.
Message quoted 1 times
Message edited by red46123 on 10-01-2011 at 02:12:26 AM
Reply to red46123
The hyper 212 is a good $30 cooler , but it simply doesn't compare to the scythe or the noctua for temperatures , and definitely not for noise .
I have been using an older version of that scythe for about 5-6 years now . The only time you hear it is at boot .
The R3 reviews I read were ok . Im sure its a good case . My two cents says that the usb 3 port on the antec would make the choice for me
Hyper 212+ is great for both overclockers and non-overclockers and it's doing pretty well with any CPU, and i don't hear it at all....
------------------------------ http://valid.canardpc.com/cache/banner/2072561.png
Reply to ilysaml
p07h34d wrote :
First thing I would change is the psu
stick to Antec, Corsair, XFX, Seasonic, Enermax for psu. Still check reviews from legit psu reviewers because some models might have issues.
Second I would change is the gpu to something like this
PowerColor AX6850 1GBD5-DH Radeon HD 6850 1GB 256-bit GDDR5 - $149.99 ($129.99 after rebate) $4.99 shipping
http://www.newegg.com/Product/Prod [...] 6814131374
with
CORSAIR Builder Series CX500 V2 500W - $59.99 ($49.99 after rebate) free shipping
http://www.newegg.com/Product/Prod [...] 6817139027
$210 ($180 after rebates)
This cooler offers great cooling at a extremely affordable price,
COOLER MASTER Hyper 212 Plus - $26.99 free shipping
http://www.newegg.com/Product/Prod [...] 6835103065
the cooler you had listed is overpriced for underperformance, if you are going to spend that much you are better off spending $30 more and picking up the best air cooler there is lol which would be this
Noctua NH-D14 120mm & 140mm SSO CPU Cooler - $85.99
http://www.newegg.com/Product/Prod [...] 6835608018
which is why I recommend the hyper 212 because I personally use it and its a great performer. That alone saves you a good $20
I suggest if you are going to buy an SSD get one that can hold Windows 7 and atleast 1 or 2 games
This ssd is a great piece of hardware, give it a firmware update and you have a beast SSD
Crucial M4 CT064M4SSD2 2.5" 64GB SATA III MLC Internal Solid State Drive (SSD) - $109.99 free shipping
http://www.newegg.com/Product/Prod [...] 6820148441
hopefully I was of some help ^_^
i agree only with the CPU cooler idea
Reply to ilysaml
PSU : the one you chose is better than some Corsair, Antec series out there, but i would go for a higher wattage one in case of future upgrades, generally Cooler Master silent pro series are rated as one of the bests...
GPU : you can put a 550Ti or HD 6850 with a BD CPU, what resolution will you be gaming at ? if you're going to game at 1080P you need at least a GTX 560Ti or HD 6950
Case: i'd recommed on of the Coolermaster HAF series, the HAF 912 advanced or the HAF 922
http://www.newegg.com/Product/Prod [...] 6811119197
CPU Cooler : Hyper 212+ and you can swap it later if you're going to be a 24/7 overclocker
RAM: G.Skill sniper are made specially for Intel Sandy Bridge platforms and some reported it has issues with AMD boards, so a 1.5/1.6V regular ram would be good chioce, here's one
http://www.newegg.com/Product/Prod [...] -_-G.skill
SSD : would get the OCZ Vertex 2 60 GG for reasonable Read/Write speeds
http://www.newegg.com/Product/Prod [...] 6820227550
Now, safe all the difference for a strong GPU and for a better CPU cooler such as V6GT if you don't want the Hyper 212+ solution.
Reply to ilysaml
The hyper 212 is a small mid range cooler . It performs very well on the cool running sandybridge cpu's .
The scythe Mugen has more heat pipes and more than double the fin surface area . Its a different class of product altogether
Will be gaming at 1080p. I have read 2 of these gtx 550 cards in sli can match a gtx 570. Which would be about 150 usd cheaper. But it seems the general consensus is to get one card that is more powerful. I agree everything I have read about the silent pro series are comparable to higher end psu's. Seems everyone is in disagreement with the Noctua NH-U12. Is it cause of price per performance or performance itself. I guess I put a little more stock in the Noctua because with the ULNA it can be 12.6 dbA. or with the stock its only at 19.6 dbA. By far the best for silent cpu cooler I have seen. Didn't see anything about that for G.skill sniper 1.25v. I liked the lower voltage for cooler operation. No matter how little is still helps. Will definitely switch it up then.
Message edited by red46123 on 10-01-2011 at 06:18:04 AM
Reply to red46123
i'm running at with my 1055T, i hit 26C IDLE and 40 Full Load (Cores Temp) and i hit 36C IDLE and 68 Full Load when i overclock to 4.0 GHz....
the CPU temp itself reported via the MOBO sensor is 30C IDLE and 60C in full load, when i OC to 4.0 it's 38-40C IDLE and 76-78C full load
Scythe Mugen is great, but when it comes to price per performance the Hyper 212+ wins...
Message edited by ilysaml on 10-01-2011 at 03:52:08 PM
Reply to ilysaml
i would SLI GTX 560Ti not the GTX 550Ti, i guess a signle GTX 570 will beat GTX 550Ti SLI as a single GTX 550Ti has a creepy performance and poor value, review this thread, it helps more
http://www.tomshardware.com/forum/314924-33-help
if you're convinced with the Noctua just grab it, my point of view is that Hyper 212+ is comparable with it and cheaper
Reply to ilysaml
CPU : Great Choice! ;)
PSU : CoolerMaster Silent Pro PSUs are good ones, but here is a better one for lesser price.
OCZ ZS Series OCZ-ZS650W 650W
http://www.newegg.com/Product/Prod [...] OCZ%20650W
Motherboard : Have a look at this ASRock board : http://www.newegg.com/Product/Prod [...] 6813157266
GPU : If you want to SLI/Crossfire, I'd recommend you to get 2 HD 6850's. They're just great for Crossfire.
http://www.newegg.com/Product/Prod [...] 6814125353
Case : Your Choice
CPU Cooler : You've chosen a nice cooler.
Memory : Its expected that Bulldozer will prefer 1866Mhz memory. These are two great RAMs :
Corsair Vengeance : http://www.newegg.com/Product/Prod [...] 6820233184
Gskill Ripjaws X : http://www.newegg.com/Product/Prod [...] 6820231455
SSD : I couldn't find a SATA III SSD under $75. SATA II ones are not that good.
------------------------------ Intel Core i3 2100, Intel DH61WW MoBo, Corsair Value 4GB DDR3, EVM (Dynet) 2GB DDR3 1333Mhz, 500GB SeaGate Barracuda, Frontech Imagine Case, Corsair CX430
Reply to 008Rohit
I wouldn't crossfire HD 6850s/70s because of microstuttering explained by toms in charts, and no i guess no need to crossfire now while a single HD 6950 or GTX 560Ti can do the job just fine .....
and better wait for the AMD 7K come out, with the news XDR2 rambus it's said to be twice faster than GDDR5, 28nm is less power consumption and heat...
Reply to ilysaml
Any affordable cards in the AMD 7000 lineup? (under $100)
Reply to 008Rohit
Case : Your Choice
I would go with the OCZ. However, I have a OCZ psu in my build right now and they burnt me on a $35 MIR. To bad, cause its a nice stable PSU. I like the G.SKill X series. Ya, I am coming to that conclusion to about SSD's. You have to spend $75+ to get anything worthwhile that won't fail or has decent speeds.
Message edited by red46123 on 10-01-2011 at 08:32:01 PM
Reply to red46123
Thanks for all the info. If anyone else wants to chime in please do so. Will still be a few weeks before I build. Waiting on Bulldozer so who knows.
Reply to red46123
There are 1481 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Gigabyte z77x not working with corsair tx750?
By smorizio, 4 hours ago:
[quotemsg=2611689,1,1216211]hi guys i need some help, im not getting any power to the...
Best offers
Top experts
