Hello, I have recently been having a problem that is driving me mad. What im expieriencing is a somewhat flickering noise coming from my headset, it ONLY happens when I am running xsplit. Xsplit is a broadcasting program that captures your screen, sound and anything else you program it to be. I originally ran into this problem with a 4 year old sound blaster x-fi gamer and figuered it was just the old age in the card. I am not using a new 5.1 rocketfish card. Everything worked fine when I first installed the driver, I can get it to work without this flickering every time I reinstall the driver till the next morning when I reboot and turn on xsplit again. For some reason idk whatever reason it is, every time I shut off the computer it corrupts it. Once again I only hear this when I am streaming.
If anyone here would be kind enough to stop by this link and skim through it. Occasionally you can hear what im going through but not nearly as bad as what I am hearing, It sounds like a choppyness mixed with a flickering.
If I could just get the driver to continue to work after the reboot process id be golden. Thanks for any advice.
The link http://www.twitch.tv/killerbeesting/b/304209939
