M MidnightRider Distinguished Jul 31, 2011 29 0 18,530 Jul 31, 2011 #1 I have amd 7750+ dual-core 2.7Ghz if i buy now gtx 550 would that be a bottleneck ???
C celpas Distinguished Dec 30, 2010 778 0 19,060 Jul 31, 2011 #2 Yes.There will be a SEVERE bottleneck.The only card you can purchase with that cpu is amd 5670.Anything above will bottleneck Upvote 0 Downvote
Mousemonkey Titan Sep 3, 2006 59,466 17 92,965 Jul 31, 2011 #3 celpas : Yes.There will be a SEVERE bottleneck.The only card you can purchase with that cpu is amd 5670.Anything above will bottleneck You keep saying that but have you actually ever tried for yourself? Upvote 0 Downvote
M MidnightRider Distinguished Jul 31, 2011 29 0 18,530 Jul 31, 2011 #4 Oh i dont beliave !!! 5670 !!! that cant be true !!!! Upvote 0 Downvote
Mousemonkey Titan Sep 3, 2006 59,466 17 92,965 Jul 31, 2011 #5 MidnightRider : Oh i dont beliave !!! 5670 !!! that cant be true !!!! Most people who prattle on about 'bottlenecks' have no idea what it truly means or have ever really seen the effects a slow CPU can have on graphical performance IMHO. Upvote 0 Downvote
M MidnightRider Distinguished Jul 31, 2011 29 0 18,530 Jul 31, 2011 #6 hmmm,so what should i do ???? Upvote 0 Downvote
Mousemonkey Titan Sep 3, 2006 59,466 17 92,965 Jul 31, 2011 #7 What resolution are you going to be running at? Upvote 0 Downvote
Mousemonkey Titan Sep 3, 2006 59,466 17 92,965 Jul 31, 2011 #9 You should be OK, a faster CPU or higher res would be better but you shouldn't be presented with a slide show at that res with a single card. Upvote 0 Downvote
M MidnightRider Distinguished Jul 31, 2011 29 0 18,530 Jul 31, 2011 #10 i had 9800 gt,1400x900 im hapy with that ,so gtx550 is OK right Upvote 0 Downvote
Mousemonkey Titan Sep 3, 2006 59,466 17 92,965 Jul 31, 2011 #11 MidnightRider : i had 9800 gt,1400x900 im hapy with that ,so gtx550 is OK right I would think so, the GTX550Ti is pretty comparable with a GTX260 192 which is only a couple of tiers higher than the 9800GT. Upvote 0 Downvote
