CPU Fan speed stuck on high after moving vid card to a new pci-e slot
- Computers
Components
Last response: in Components
italianmonti
January 1, 2012 7:18:19 AM
When I built my computer last year around this time, the case I had was very difficult to use with the giant video card I had. So ideally I just stuffed it all in there. Today I decided to move the video card down a PCI-E slot so it would not be so close to the sound card. Once I moved my video card down a slot and I booted my computer again. My CPU Fan is idling at 2000rpm. I'm not quite sure what might have happened.
*NOTE* just before I was about to shut off my computer I accidentally hit the power strip shutting everything down unexpectedly. I'm curious if maybe that caused hardware damage and would make my CPU fan blaze and a whooping steady 2000 rpm.
Can someone please help me with this problem? I cannot stand to listen to this fan at full speed; especially when it is not needed.
Please can someone help me with this problem.
Windows 7 64-bit
Asus P6X58D Premium
Core i7 950
Nvidia 480 GTX
6gb triple channel ddr3
Creative soundblaster fataility titanium
PC Power & Cooling Silencer 910 Watt
Windows 7 64-bit
Asus P6X58D Premium
Core i7 950
Nvidia 480 GTX
More about : cpu fan speed stuck high moving vid card pci slot
ukee1593
January 1, 2012 7:59:58 AM
Its possible that the Motherboard BIOS got corrupted when the computer was turned off unexpectedly, but very unlikely.
I would try resetting the BIOS to factory default via the BIOS interface (press esc, or del or whatever to enter BIOS setup) and restore to defaults there. If that doesn't work reset the CMOS by following the motherboard instructions.
Get back to us if that doesn't work ...
Luke
Luke
m
l
italianmonti
January 1, 2012 3:46:27 PM
I read somewhere to turn on CPU Q-Fan and set to standard, this seemed to fix my problem at the moment. Is that something I should do?
However, I did reset my bios to default settings.
The fan is out of control again, and I remember when I first bought my computer. I have 1600 triple channel ram and it always sets it to 1066. I had a friend fix this at one time, he told me in the past something about cpu multiplier which I know nothing about.
m
l
- CPU fan speed still high after new video card - Forum
- Computer doesn't recognize my video card after I moved it to a new PCIe slot? - Forum
- help! cpu fan stuck on high speed! - Forum
- New CPU fan running at very high speed (Arctic Cooling Freezer 7) - Forum
- New CPU/mobo. Very high CPU fan speeds - Forum
cbrunnem
January 1, 2012 4:14:44 PM
italianmonti
January 1, 2012 5:21:02 PM
The funny you say that. I use an Antec and it has two compartments for harddrives. I had my harddrives in the lowest compartment and I moved them to the highest just below the Audio Console and DVD Drive. The fan that cools my HD (?) is about 80-90 below the cpu fan; I'd say only 10-20 percent of the fan is pushing at the CPU fan.
Any idea on if the Q fan is a good idea? and what about my ram? I reset it and now I cannot get my ram at default settings unless I clock it to 1600
m
l
cbrunnem
January 1, 2012 5:54:02 PM
italianmonti
January 2, 2012 12:23:15 AM
cbrunnem
January 2, 2012 12:35:51 AM
italianmonti
January 2, 2012 1:00:45 AM
italianmonti
January 2, 2012 8:02:10 PM
cbrunnem
January 2, 2012 8:30:36 PM
italianmonti
January 2, 2012 11:14:27 PM
cbrunnem
January 3, 2012 12:00:19 AM
thats up to you. but just remember the cooler you keep things the better and longer they last.
http://www.quietpcusa.com/how-to-silence-a-computer.asp...
if it was me id run them full speed all the time. i assume this is a gaming computer so whats the big deal? you shouldnt be able to hear the fans when gaming unless for some reason you have the sound down all the way.
m
l
italianmonti
January 3, 2012 1:55:44 AM
I have probe running on my computer. I do not know if this is normal or not. At idle its about 38-40 degrees. when I'm working on the pc (movies, facebook, forums, skype, etc.) it runs about 40 - 47. I stress tested it and it went up to almost 60 or so. I wonder if I should be concerned. Before when I had my original setup I never really checked it and wonder if this is normal. the fan runs at 1500 rpm with casual use. and 1200 at idle.
I looked into it some say its normal. Should I take the fan off and reapply my artic silver ?
m
l
cbrunnem
January 3, 2012 2:30:09 AM
italianmonti said:
I have probe running on my computer. I do not know if this is normal or not. At idle its about 38-40 degrees. when I'm working on the pc (movies, facebook, forums, skype, etc.) it runs about 40 - 47. I stress tested it and it went up to almost 60 or so. I wonder if I should be concerned. Before when I had my original setup I never really checked it and wonder if this is normal. the fan runs at 1500 rpm with casual use. and 1200 at idle.I looked into it some say its normal. Should I take the fan off and reapply my artic silver ?
im not quite sure what you are saying. "i have a probe running on my computer" what do you mean by that?
those temps dont seem bad. this is a none overclocked i7 with the stock heatsink correct?
m
l
italianmonti
January 3, 2012 12:04:37 PM
cbrunnem
January 3, 2012 4:49:12 PM
italianmonti
January 3, 2012 8:44:50 PM
Read discussions in other Components categories
