Better case? Fractal Design Midi vs Corsair Obsidian 650D
Which case, given the same price range (I know the corsair is a fair bit higher), is the better of the two in terms of features, cooling, and dust filtering (I don't care too much for looks):
Fractal Design Midi:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811352007
OR
Corsair Obsidian 650D (I can finance this one too from a different site, so price is not a factor)
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139006
The Fractal simply does not have a filter on the side fan slot which is the only thing that bugs me on that case. If someone could give me inside on dust entering from the side of the case or possibly adding a fan, that would be very helpful.
The Corsair 650D simply doesn't have an internal motherboard header for the 3.0 USB, which I'd like just in case. I could buy an adapter I suppose, but it'd be an extra hassle and extra cash.
Any help would be much appreciated!
Thanks.
1 answer Last reply
More about better case fractal design midi corsair obsidian 650d
  1. I like more Corsair it have more External 5.25" Drive Bays. It have better cooling with 2x200 mm fans and 1x120mm fan. If you have an aftermarket cooler ,i don't know if you can put and use the side fan.
Power Supplies Cases Corsair Components Product
