System i am building now please help. thanks
  • Homebuilt
  • Systems
  • Product
Last response: in Systems
October 1, 2011 3:52:42 AM
ok hi everyone this is my set im im looking to buy right this sec.
motherboard - asrockx58 extreme lga 1366 intel atx
processor - intel i7-950 or something like that may be cheaper
ram - mushkin enhanced silverline 6gb http://www.newegg.com/Product/Product.aspx?Item=N82E168...
video card - evga o1g-p3-144 i want hdmi ports
case on newegg not sure what one.
if someone can help me out please with links from newegg, on what ones to buy and if they will work on this sytem or if something se cheaper and better , im going cheap on this build thank you very much.
More about : system building
a b B Homebuilt system
October 1, 2011 4:27:34 AM
COOLER MASTER Storm Scout SGC-2000-KKA3-GP Black Steel / Plastic ATX Mid Tower Computer Case w/ Cooler Master RS700-PCAAE3-US 700W Power Supply $129.99 and a $15 rebate= $114.99
This case comes with a power supply so it takes care of two things.
Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) 4 x 256KB L2 Cache 6MB L3 Cache LGA 1155 95W Quad-Core Desktop Processor BX80623I52500K $219.99 and free shipping.
ASRock Z68 Extreme4 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard $184.99 and free shipping.
G.SKILL Sniper 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL9D-8GBSR $48.99 and free shipping
Going this way ( cpu, mb and ram) you save $70 and you end up getting a better computer. I took the components you had listed , mb,cpu and ram for $517.97 on Newegg and sustituted them for $453.97 , a $70 savings.
m
l
October 1, 2011 4:32:28 AM
What were you going to spend on a video card and what were you looking at.
EVGA 01G-P3-1556-KR GeForce GTX 550 Ti (Fermi) FPB 1GB 192-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card $137.99 with a $20 rebate =$117.99
http://www.newegg.com/Product/Product.aspx?Item=N82E168....
m
l
October 1, 2011 4:53:26 AM
Whilst the CM case is nice, I'd think twice about using the PSU with it. CM aren't the best brand for PSUs, it's not even 80+ rated (that I could see/find) so you'd be selling yourself short there. Go for one like an XFX...much better in the long run.
m
l
October 1, 2011 12:35:57 PM
I want to spend 80. Or less on a video card I have a 700psu already . I'm building this system for someone so the best isn't what I'm going for the cheapest I am I guess he gave me 600. To work with I found a open box on newegg on the motherboard for 119. So I'm def getting that one I just need cheapest ram that'll work with it . On the case I wanted to get 30. One thatll fit the mobo I don't really care what it looks like just as long as it'll fit. Video card I want 80. Or less one with a hdmi port nothing to expensive . Thanks
m
l
October 1, 2011 8:33:07 PM
Anybody can help me out I wanna buy it tonight thanks
m
l
October 2, 2011 2:29:19 AM
thanks but i wanna stick with the layout i have, can anyone help me out with my layout thanks
m
l
