I have a ASRock Z77E-ITX Mobo:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157312
My Wifi antenna that came with it got damaged really bad, so I need to replace it. Can I just use any old antenna? Like this one?:
http://www.amazon.com/Mini-Antenna-RP-SMA-Bulkhead-Pigtail/dp/B007XVHQ9M
Or is there a specific one? Any antennas you recommend? I like low profile ones...
Thanks!
Thanks!
