Yes No
Ads
Tom's Hardware > Forum > Systems > Homebuilt > [Solved] I need some help with the power supply calculator
Forum Systems : Homebuilt [Solved] I need some help with the power supply calculator
Best answer from utdarkviper.
I looked at the eXtreme Power Supply Calculator(http://extreme.outervision.com/PSUEngine) and I don't know if my motherboard (http://www.newegg.com/Product/Product.aspx?Item=N82E16813131711) would qualify and a "High End - Desktop" motherboard or a "Regular - Desktop" motherboard? Also does a 7200 rpm sata drive qualify as "regular sata" or "high rpm"? Finally would the fans that came with my antec 300 case be "regular" or "high performance" fans
Reply to perfect_disturbance
Best answer
Since this is an estimation tool, I would always choose the higher power consuming answer just in case. So, I would use...
High-end Desktop for the motherboard
7200rpm is regular sata, 10,000rpm is high rpm
those fans are regular
It's always good to go a little higher than the PSU calculator suggest anyways, and that covers little things like this too. =) For example, if it says 523W then go with a 550W or 600W. I went with a 850W when it recommended 550W or so (much more than enough) and I'm glad because I am upgrading to a second card and dont have to worry! It's all up to you!
Reply to utdarkviper
so what would be the difference between high performance and regular fans?
ones that operate at some seriously high rpms lol
the fan type doesnt really matter much, but I dont think any fans that come stock are high performance
There are 1492 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Gigabyte z77x not working with corsair tx750?
By smorizio, 4 hours ago:
[quotemsg=2611689,1,1216211]hi guys i need some help, im not getting any power to the...
Best offers
Top experts
